1Back to top Go down   torque trouble Empty torque trouble Tue Mar 29, 2016 6:00 am
Howard64180
Howard64180
For years I have greased all nuts and bolts on assembly, with the exception of wheel bolts.  Never had a problem and they are always easy to undo next time.
However, I now have two things I never had in the past: the Internet and a torque wrench.
So, apparently using (lithium) grease on a fastener:
is a good thing because it overcomes friction which would decrease torque values
is a bad thing because it overcomes friction and will increase torque values
doesn't matter because my torque wrench is wrong anyway
doesn't matter because manufacturers allow safety margins in the torque figures
doesn't matter because in any case my handlebar mounting bolts are going to snap, my rear shock will break along with my drive shaft, my rear brake will seize, my electrics will get on fire, and my rear wheel will fall off.  AND my rear shock stud, which started this train of thought in the first place, will snap (though I do now have a support for this stud, courtesy of Sidecar Paul).
2Back to top Go down   torque trouble Empty Re: torque trouble Tue Mar 29, 2016 7:08 am
I know where you're coming from!
I think this will be more entertaining than an oil thread!
What do I do? I put blue Loctite on everything.
Last edited by blaKey on Tue Mar 29, 2016 7:09 am; edited 1 time in total (Reason for editing : afterthought)
3Back to top Go down   torque trouble Empty Re: torque trouble Tue Mar 29, 2016 8:33 am
blaKey wrote:I know where you're coming from!
Ha, we are tyred of oil threads...
We use Loctite torque trouble 905546712 here too, but its black.
On a more serious note it is quite a significant topic and of relevance to K owners.
4Back to top Go down   torque trouble Empty Re: torque trouble Tue Mar 29, 2016 8:55 am
rawdonball
rawdonball
threadlock's probably great insurance where the specified torque on a fastener is mainly about ensuring it doesn't come loose. The more critical ones are obviously cases like the lower mounting for the rear shock that seems to suffer from reduced fatigue resistance if too loose or too tight. At least if you use thread lock you are not as tempted to make it too tight!
5Back to top Go down   torque trouble Empty Re: torque trouble Tue Mar 29, 2016 10:23 am
bugger it, I just use a nylon based lock nut on the rear support bolt of the shocky ...sorry I know it will fail, just not sure when, but the scp support bracket will help ....
thank heavens for our old mate  in Birmingham
all hail scp ... torque trouble 112350
6Back to top Go down   torque trouble Empty Re: torque trouble Tue Mar 29, 2016 11:05 am
torque trouble 4_17_210
7Back to top Go down   torque trouble Empty Re: torque trouble Tue Mar 29, 2016 1:01 pm
92KK 84WW Olaf wrote:
blaKey wrote:I think this will be more entertaining than an oil thread!
And as Olaf rightly points out, tyre t(h)reads as well.  👅
8Back to top Go down   torque trouble Empty Re: torque trouble Tue Mar 29, 2016 2:27 pm
What's wrong with green Loctite? It's oil-resistant too (see what I just did Olaf? Cool ).
9Back to top Go down   torque trouble Empty Re: torque trouble Tue Mar 29, 2016 5:25 pm
Did you read the intro of the new member with the trike?
The PO found the solution: Cheap and efficient as the nuts will never break loose. WELD them! torque trouble 39723
torque trouble Frog15torque trouble Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
