Number of posts : 7967
Welcome too.
As for the engine, no need to go into it too far at all 60k kilometres is just run in. Lots of high miles engines around, the known issues are well documented on the forum. Point secen five sums it up well but am adding a few more.
Oil/water pump
Rear engine seal.
Spline lubes
Rubbers like intake, fuel lines, crank case breather.
Fuel injectors/tank/pump need cleaning.
Fluids
Filters.
Brakes clean out, likely fail of master cylinders so probably wise to just do them with repair kits.
Water pumps changed and the early type with a nut on the impeller are not recommended and in fact usually break when you try to do them. On mine I ended up with a new shaft as it was also pitted/worn, so wiser to go the full way and get newer shaft/seals/impeller etc. Intricate little job but great access.
Rear disc looks original, later ones are solid.........the perforated ones seemed to have crack issues. I put a brand new solid rear disc on 2 years ago and quite amazed at the amount of wear. Put new tyres on at the same time and have since fitted 3 more sets.
Centre stands are prone to breaking, the part that you press down with your foot snaps off with the bottom of the stand. You can weld in reinforcement or do an upgrade. [looking at the photos again seems that's been done....]
Your photo looks like an early type seat. You should be aware drive shafts changed, from 16 to 20 spline and you need to know which when you go looking. They are not interchangeable.
I may be opening a can of worms here suggesting this but sprag clutches can give bother. Recently 88 on the forum did a mod suggested elsewhere on the forum. This involves drilling into the engine to make an access hole for penetrating oil to free it up. Saves separating the engine and its quite a cinch. Special tapper then for the hole so you can access anytime you need. Done last week and has worked.
A second small but useful mod is Sidecar Paul's fuel cap hole so you can open the gas tank if the opening mechanism fails as it will in time. A very simple one but then allows you to use a screwdriver to get it open. I had to do this recently and it saved the expensive cost of replacing the cap as it comes as a complete assembly.
For comfort a new clutch cable might be good, amazing the difference it makes. Very important to lubricate the nipple in the lever, if sticks and if it cant rotate as you use the lever the cable will snap off pronto and the nipple falls away down under. BMW in their wisdom do not include the nipple or the little sleeve it sits in with the clutch cable so wise to get one and keep it spare somewhere.
If you go into splines check out the gear position indicator sensor, swing arm has to come off to access it so that's your chance to take it out and clean it.
In the photos the oil level window looks solid back. Just check the oil level, it should be to the centre of the window, to the red dot. The red circle marks minimum and maximum. They don't like too much oil and that can cause seal issues.
If you put the VIN into your signature anyone with more technical knowledge than me can point you in the right direction.
After that just enjoy the K....
1971 Yamaha 125 YAS-1
