1Back to top Go down   Dash pad accessory switch Empty Dash pad accessory switch Tue Mar 08, 2016 4:08 pm
KeithK
KeithK
I am in the middle of a RS to LT handlebar switch. On my new dash pad, I now have 4 switch locations instead of the 3 that I had on my RS pad, and I have a new powerlet socket hole.
I am going to wire in a powerlet to the new dash pad and thought since I have an additional switch location, it would be a great opportunity to add a switch for the new powerlet (I am planning to use the non switched hot terminal in the anti-theft connector). I have been looking online for a couple weeks now and haven't had a whole lot of luck finding a new switch, what are my options for the physical switch? I already have the hazard, ABS, and heated grip switches in the dash pad so I want something with either a different "icon" or even no "icon".
I have only found one option at this point, located on this site: https://www.motobins.co.uk/mobile/bmw-parts3.php?bikeref=&P=3&model=&M1=93&M2=16590
Dash pad accessory switch 85304
Has anybody used something like this, and if so, what tile did you use/where did you get the tile?
Also, can anybody help with the correct powerlet socket to fit in my dash pad hole, and not interfere with anything behind it? Do I need to use an elbow socket like this:
http://www.powerlet.com/product/powerlet-socket-low-profile-kit/285
Dash pad accessory switch ImageResizer.php?image_type=PRODPRIM&fileName=PSO-007_p_141_webl
Any other input on my project would be appreciated!
2Back to top Go down   Dash pad accessory switch Empty Re: Dash pad accessory switch Tue Mar 08, 2016 4:42 pm
I have used this switch a few times.
1. On my K1100RS to replace the ABS switch and give it a dual function.
This switch in one position is a standard on/off switch,  in the other position only on when pressed. So ABS reset as before and also a FAN on switch. I used the original ABS tile.
2. On my K100RS I used one of these as a standard on/off switch for the power to my GPS. For the tile I printed out GPS on a Black Background on a Brother Label printer.
Motorworks do a Blank insert (tile)
Rocker switch insert blank | ELA59363
Dash pad accessory switch Ir-log10
 ;BMW; K1200RS Red
3Back to top Go down   Dash pad accessory switch Empty There are 11 different switch inserts Tue Mar 08, 2016 10:36 pm
There are 10 different switch inserts with 11 part numbers:
Fog/Tail Lamp
Heated grips
Blue (no graphics)
Orange (no graphics)
Cop lights
Horn (trumpet)
Blank black
Hazard
ABS
Windscreen (green)
Some of the early original hazard switch had a filament bulb behind them but those didn't last too long.
But you can backlight the translucent ones with 3mm LEDs to make them easier to find at night:
Dash pad accessory switch Led.sw2
4Back to top Go down   Dash pad accessory switch Empty Re: Dash pad accessory switch Tue Mar 08, 2016 11:11 pm
KeithK
KeithK
Thanks for the info on the switches.
Any input on the correct powerlet socket?
5Back to top Go down   Dash pad accessory switch Empty Re: Dash pad accessory switch Tue Mar 08, 2016 11:24 pm
I usually tap the dash Powerlet socket into the factory one under the seat (which is unswitched.)
Rationale:
1) Keeps them on the same fuse.
2) I like them unswitched as it makes plugging my tender in easy.
3) I usually run my dash Powerlet into an electrified tank bag where I charge my electrical gear and like to be able to do that when the bike is parked. If I don't want to risk draining the battery then I just pull the Powerlet plug.
6Back to top Go down   Dash pad accessory switch Empty Re: Dash pad accessory switch Tue Mar 08, 2016 11:40 pm
KeithK
KeithK
I was planning on having the powerlet on the switch to more easily turn on/off heated gear rather than plugging in and pulling the plug out while riding.
I am more looking for input on which powerlet socket would best fit on the dash pad. I don't know if the socket with the immediate elbow is required or if you can fit one of the more standard straight socket in without interfering with anything behind it. There seem to be dozens of choices for sockets on the powerlet website.
7Back to top Go down   Dash pad accessory switch Empty Re: Dash pad accessory switch Wed Mar 09, 2016 12:46 am
I have always used the straight one with 2 x 6mm spade connectors
Have you considered a Pulse width modulator (PWM) to control the heat they work very well and are really cheap on fleabay, around $6.
8Back to top Go down   Dash pad accessory switch Empty Re: Dash pad accessory switch Wed Mar 09, 2016 3:36 am
What heated gear a re you buying that doesn't have its own control unit?
9Back to top Go down   Dash pad accessory switch Empty Re: Dash pad accessory switch Wed Mar 09, 2016 1:11 pm
KeithK
KeithK
Firstgear sells a heat controller for their heated gear separately but I dont want to buy that if I don't have to. I also don't want to deal with mounting a hear controller or other PWM controller.
