Number of posts : 4462
1) Modulator
2) Caliper
On the front master:
Turn steering to full lock left to get the master mostly level.
If you leave the lid off when bleeding then you need to pull the brake lever in V-E-R-Y slowly. If you pull it in too fast you will get a little fountain of brake fluid that may get on your bike.
Probably not a bad idea to put some paper towels under the front master while bleeding it.
