1 Three and a half cylinders and a diesel knock knock knock knock....... Mon 15 Feb 2016, 14:03
This all started after the crash; prior to that the engine was running perfectly with no nasty noises to upset me. What I've done:
Re-checked the clutch adjustment
Changed the spark plugs
Changed the HT leads. When I came to check the No.1 Realm Engineering lead I found the connector a nice colourful shade of green with a matching coil post to go with it. On peeling back the rubber cover to clean the HT connector, the HT connector fell out. Shall we say the crimp wasn't as good as it could have been, especially when compared to the other three. LFB now has BMW leads in from Brick 2. That reduced the diesel injection slightly.
Checked ALL of the FICU and ICU connectors and wiring (I built it, so...)
Changed the ICU
Changed the FICU
Checked the throttle bodies for balance and synchronicity.
Starting is... a bit odd. It almost instantly fires on all four pots but within a second or two the diesel knock kicks in quite loudly. Pulling the clutch in reduces the noise marginally, as you'd expect when the gearbox is decoupled. Give it a handful and hold it at about 1500rpm for ten-fifteen seconds, drop it back to idle and the diesel knock reduces to almost inaudibility. Leave it for a minute or three, the knock disappears and tickover settles to between 960 and 980 rpm.
BUT.
It feels like someone has removed half a cylinder. I struggled to get LFB above 95mph on the M1 back from Dublin on Sunday and in general, kicking it down into third to overtake feels more like just opening the throttle up in fifth gear. Opening it up in fifth gear to overtake is inviting the nearest hearse to pay a visit. Either way, giving it a handful induces a low-level diesel knock again (could possibly be an intermittent misfire, I guess. Difficult to be absolutely certain over the wind noise).
Anybody any guesses as to what I've shaken loose? What I haven't checked because I keep forgetting is our old friend the rubber pipe between the airbox and the plenum chamber.
Changed the ICU
Changed the FICU
BUT.
