1Back to top Go down   Cooling system questions Empty Cooling system questions Wed Feb 24, 2016 3:58 pm
SniperX
SniperX
So, what coolant to use? Any quality or does master BMW say only one or it'll go thermo nuclear? Since I am a BMW car guy and they have a closed system that needs to be burped, is the k bike same? How about special instructions on this if it is the way?
1985 BMW K100RT, 2006 Ducati ST3, 1996 Honda CBR1000f, 2001 Honda XR400r
2Back to top Go down   Cooling system questions Empty Re: Cooling system questions Wed Feb 24, 2016 4:44 pm
I have always used the green glycol. There are no real special instructions but I leave it on the side stand then as it gets full squeeze the hose so that any air comes out then when nothing more will come put the cap on and fill the overflow container to the full mark and keep an eye on it for the next few rides and top up if needed.
I have never had trouble with air pockets unlike the E36 6cyl I had that had to be burped very carefully.
3Back to top Go down   Cooling system questions Empty Re: Cooling system questions Wed Feb 24, 2016 5:23 pm
SniperX
SniperX
RicK G wrote:I have always used the green glycol. There are no real special instructions but I leave it on the side stand then as it gets full squeeze the hose so that any air comes out then when nothing more will come put the cap on and fill the overflow container to the full mark and keep an eye on it for the next few rides and top up if needed.
Yes, my E28, E9 and E3s are all very prone to being burped perfectly or they'll run hot. Good to hear the K isn't the same!
4Back to top Go down   Cooling system questions Empty Re: Cooling system questions Wed Feb 24, 2016 6:15 pm
agree with rick ....pretty easy to do
but be aware about the cap seals
if the inner one doesn't seal properly ...strange things happen during operation and city street travelling ...and climbing hills
I found a suitable ring seal replacement  that solved an overheat suspected issue of emptying the reservoir and steam up the inside leg at moderate temperatures ...with fan to come on type riding events
good luck
