1 Thanks for the help everyone, it's on the road Fri Jan 09, 2015 3:55 am
ausbrick
My chair lives, will post a few pics soon. Planning on building a second body, basically a large box set up for camping. Cheers, ausbrick
Hi Sean, good to see you back,Saxon7 wrote:Hello Mr Ausbrick,
Nice looking outfit and nice boat too. Just looking at your front top mounting point: it looks a little low. Do you have any issues with the bike "settling" against the chair so far?
Schoorn.
One outfit I had used this mounting point. What happened eventually was that the frame cracked back under the seat, apparently because the headstem could twist a little during cornering. A higher mounting point and some bracing would help with this. In fairness though, that outfit was pounded along a lot of dirt roads which cant have helped. I expect on mainly sealed roads it would be fine. Philsidecar paul wrote:Hi Sean, good to see you back,Saxon7 wrote:Hello Mr Ausbrick,
Schoorn.
My top front fitting is at the same point as Ausbrick's, ie the top engine fixing bolt. No problems for the past 100+ K miles or so.
K100-forum.com » Technical, repair and troubleshooting » Everything about adding a chair(sidecar) on a K Bike..... » Thanks for the help everyone, it's on the road
Similar topics
