half brick
half brick
Whats the least CCA I need in a battery for an 8v K100?
I can't find a spec for that anywhere, only the Ah.
K100 LT 1989
The smallest battery I've run in a K is an ETX15L which has 220 CCA in a K100.
Starts the bike just fine but I would only recommend it for a bike that gets ridden regularly or is kept on a smart trickle charger.
It isn't a ton of current but the K clock is always draining the battery and if left unridden long enough will discharge the battery.
half brick
half brick
Thanks, I've ordered one with 260 CCA so should be plenty.
K100 LT 1989
