1 ABS issue on K100 RS SE Sun Feb 21, 2016 9:49 am
yetti.86
Hi folks.
I've bought K100RS ABS Special Edition 89. Bike is in average condition, after clutch repair with 120000 km on the clock. Everything working except ABS. Nevertheless I've performed several steps to repair ABS system and I've reached some results. Anyway it isn't still in 100% condition.
So current state is following:
1) When I turn the ignition on, the bulb monitor light and ABS light flashing alternately.
2) ABS error code is zero. Led connected to the middle pin of ABS diagnostic connector illuminates permanently.
3) When I ride several meters, lights stop flashing. Bulb monitor light goes off and ABS light remains lighting (without flashing).
4) When i tried braking on gravel, where is easy to block wheel, I felt that ABS on rear wheel is working. I did not tried this with front wheel because I was not brave enough. .
5) When I pressed ABS switch on dashboard, nothing changed with warning lights (ABS light on, bulb monitor off), but when I tried to lock rear wheel again I felt that ABS system did not work.
6) Finally I wanted to check, that my diagnostic method of ABS brain is correct, so i disconnect rear sensor and after turning the ignition, I've seen four flashes of diagnostic led in the pin 2. of ABS diagnostic connector. So this ensured me, that ABS brain send me correct diagnostic pulses. After the reset of the unit, I've got the zero code again - no blinking, just continous light.
So, briefly:
- I'm pretty sure, that ABS system is working at least for rear wheel.
- ABS brain do not send me any fault code.
- ABS red warning light iluminates permanently during ride.
It will be very helpful for me to have a complete wiring diagram of K100RS ABS, because I've feeling that my ABS system is working, but problem is somewhere in the relays.
I think my bulb monitor unit is somehow ill. When I unplug both rear lamps, the bulb monitor light is not illuminate and this apply for the case, when ABS brain in connected to the bike as well as case when ABS brain is disconnected.
So can broken bulb monitor unit cause this behavior of ABS warning light? Or is there still a problem with ABS system?
What do you think? Regards Milan.
So, briefly:
