Ferg
Ferg
Hi guys,
I have a 1984 K100 but the tank had some erosion on the top,in front of the petrol cap - from the cavitation pipe metal tube.
A replacement (1993?) K1100 tank has been purchased and 'sprayed', this did not come with a fuel pump so I am finding a problem fitting the pump to the newer tank as the fabricated aluminium housing is of a different design to the 1984 model.The round aperture is good but there is no allowance for the breather side exit pipe on the basket filter, so the filter cannot be lowered and clipped in place.
This is difficult to explain unless somebody has previous and I suppose a photo would be a great help to visualize but I think I could cut a small piece from the housing to allow the pump to rest as it should, also there is no metal tube in front of the petrol cap for the cavitation pipe to attach to - Q: If I can get the pump seated would it be okay to just strap the pipe high up in the tank? it doesn't have to be pressurized, does it?
Chocolate
Chocolate
Hello Ferg!
Not getting 100% the point of what you are telling.
Pictures would be great! :-)
Fuel pumps you can get for 30£ on eBay for other purposes or for your K specific.
Here is a example
Fuel Pump on Internet
This is how the pump looks like
K1100 tank will not accept K100 fuel pump. <a href=K1100 tank will not accept K100 fuel pump. Image22" />
K1100 tank will not accept K100 fuel pump. <a href=K1100 tank will not accept K100 fuel pump. Image23" />
Ferg
Ferg
Yeh cheers.
Mine is a 52mm diameter pump that works fine and would prefer to use it, yours has a soft basket that would be no problem to fit - but no breather pipe? do they give a smooth delivery of fuel then? I suppose that would eliminate the problem of where to mount the breather pipe to, that exits from the mesh basket, not so many 52mm kinds for sale at a cheap price though.
Ferg
Ferg
K1100 tank will not accept K100 fuel pump. FP-576KIT-6
Just found this in America but would cost about £40 to receive so will just modify the basket I have - with the fuel return outlet.
I may not have been given the correct details of the production date of the tank I purchased, although it has come off a K1100.
