1Back to top Go down   K11RS ABSII Empty K11RS ABSII Thu Mar 03, 2016 8:58 am
Reg
Reg
Guys
Wou8ld anybody have a step guide to bleeding the brakes on a K11rs, especially where to start on the ABSii unit. ??
2Back to top Go down   K11RS ABSII Empty Re: K11RS ABSII Thu Mar 03, 2016 11:26 am
1) Modulator
2) Caliper
On the front master:
Turn steering to full lock left to get the master mostly level.
If you leave the lid off when bleeding then you need to pull the brake lever in V-E-R-Y slowly.  If you pull it in too fast you will get a little fountain of brake fluid that may get on your bike.
Probably not a bad idea to put some paper towels under the front master while bleeding it.
3Back to top Go down   K11RS ABSII Empty Re: K11RS ABSII Fri Mar 04, 2016 6:41 am
Reg
Reg
sorted.. thanks, purchased a hose with non return valve.. the right tool for the right job..K11RS ABSII Icon_cool
