1 Electrical Question from a newb! Sun Jan 17, 2016 8:02 pm
energyhutch
I have another question, but wanted to say thanks again for the help that the community has already provided in my short K100 life!
I bought an 1985 BMW K100 which was running, but had required hot wiring in order to run and a "permanent hot wire" was set up, I removed all the jury rigged wiring and reinstalled a newish right side hand controls and wired the bike per the online diagrams. However, when I turn the ignition on and depress the clutch, then press the start button - the fuel pump runs and you can hear fuel feeding - but absolutely nothing from the starter. Nothing turning over or anything. Battery is full and it RS prior to my supposed correct rearrangement of wiring. My question is, if the starter is not even making a peep - where should I start? Thanks in advance, I truly appreciate it!
