Number of posts : 7963
85RT?
No you don't need to remove the fairing.
1. Remove the 2 storage boxes, screws are inside it, 2 at the front, 2 in side and 1 each side beside the latch, seen from above. The ones either side of the latch may or may not come but will unscrew. Turn handlebars to opposite lock to make sure you can lift the parts free.
2. The leg lining at your toes has a single screw....remove this. You kind of have to look up from underneath.
3. The leg lining and storage box may come out together with those two screws at the latch still in place. Lift the rear of the storage box and it will come clear. With the bars on opposite lock it will come out.
4. On each side you will see the box has exposed a black metal frame. Should be 4 screws in this, Remove these and remove the frames.
5. After you lift out the storage box frames you will see or should see a horizontal filler piece/baffle with some screws into the fairing where the lower and upper fairing meet, one left one right. Remove these.
6. On left side there is also a baffle against the airbox, it has 2 screws. Remove this too.
The fairing lower panels are next to be removed. BUT...... with a little tweaking its not necessary to remove them to get the tank off.! If you do as the last paragraph you wont need the fairing lowers off next time you have to remove the tank.
7. Left side has two screws at the front, into the radiator surround, facing toward the centre of the forks. Remove these. Right hand one has two screws also, top one is at the corner of the radiator panel, bottom one is accessed from underneath so you must look from underneath the corner as its easily missed. The fairing lowers have tabs that go into the radiator panel for these screws.
8. On each of the fairing lowers you will see where there are brackets onto the engine and 10mm nuts on the fairing to bracket connection. Remove the 10mm nuts.
9. From above looking down on the fairing to lower panel joining there should be more screws, 2 or 3.
10. As you do 8 and 9 you will feel the lower panels loosen, not heavy but mind them and have somewhere soft to lay them. Take them by the rear and move it out as you withdraw the tabs from behind the radiator panel.
If you can disconnect the fuel lines at the front of the tank, also disconnect the electrical plug, it can be done through the left lower panel but only if the screw pipe clamps are correctly aligned to access them through the ventilation slots. If so there is no need to remove the left lower panel next time you need to remove the fuel tank, a helpful matter in a breakdown. However if the bike is new to you replace the fuel lines as they perish with slightly longer..... You will need right hand fairing lower and the bottom of the air box off to access the connector onto the FPR Fuel Pressure Regulator. Again, aligning the pipe connector smartly will allow a screwdriver to slip between the airbox and electrical box to access it next time.
1971 Yamaha 125 YAS-1
