1Back to top Go down   Please Help To identify Parts Empty Please Help To identify Parts Wed Nov 18, 2015 7:49 am
SBKman
SBKman
I'm restoring a 1985 K100RT and obtained it partially dismantled.
Can anyone identify these fairing/frame parts?
https://s664.photobucket.com/user/kevin01471/library/K100RT
thanks in anticipation
kevin:o
2Back to top Go down   Please Help To identify Parts Empty Re: Please Help To identify Parts Wed Nov 18, 2015 9:06 am
No 1 I can't place.
No 2 is an internal baffle inside the RT fairing, it is fitted at a slope before you fit the box and leg shield panel. There should be one left and right but they are not identical. There also should be two longer horizontal baffles, about 30cm long and part curved, they are fitted with 3 screws at the top of the joint where the main fairing and the lower panels meet.
No 3 and 4 seem to be the foam fillers/air blockers that go under the petrol tank.
No 5 and 6 seem to be the deflectors that go behind the headstock? I have never had mine off but there seems to be something like them there.
Olaf
Last edited by 92KK 84WW Olaf on Wed Nov 18, 2015 10:33 am; edited 1 time in total
3Back to top Go down   Please Help To identify Parts Empty Bits I can't identify Wed Nov 18, 2015 9:35 am
SBKman
SBKman
Cheers Olaf
it narrows the search area down a bit.
Smile Smile Smile Smile Smile
4Back to top Go down   Please Help To identify Parts Empty Re: Please Help To identify Parts Wed Nov 18, 2015 11:33 am
It's difficult to determine its dimensions, but is that first picture of a number plate backing plate which screws to the rear mudguard?
Registration plate mounting 46 62 1 453 692 US$9.39...
5Back to top Go down   Please Help To identify Parts Empty Re: Please Help To identify Parts Wed Nov 18, 2015 11:41 am
Two Wheels Better wrote:It's difficult to determine its dimensions, but is that first picture of a number plate backing plate which screws to the rear mudguard?
The granite background is confusing......but the grain size would make that about right...... I haven't seen that part on my RT and the number plate is one place I have not had apart.
6Back to top Go down   Please Help To identify Parts Empty mystery parts Wed Nov 18, 2015 11:50 am
SBKman
SBKman
Yes the first item is the number plate  backing plate. cheers
should have carried out a search on the part number stamped on the back doh!!!!!!!Embarassed
7Back to top Go down   Please Help To identify Parts Empty Re: Please Help To identify Parts Wed Nov 18, 2015 12:08 pm
SBKman wrote:Yes the first item is the number plate  backing plate. cheers
That's what we're here for.  Please Help To identify Parts 905546712 Please Help To identify Parts 44271
