1Back to top Go down   Replacement Fuel Pump Empty Replacement Fuel Pump Wed Nov 04, 2015 1:51 pm
Kiwi_Roy
Kiwi_Roy
Hi, The K 100 I am looking at in NZ has been sitting for a year, when the owner tried to fire it up it cranked but wouldn't fire, he figures it has a failed fuel pump (wouldn't run on the bench but I don't know it was open circuit or just stalled), my Bro will go have a look and see if he can get it going.
Just in case the pump is toast is there a cross reference to an automotive substitute?
I don't think they have the equivalent of NAPA in Kiwi Land
I'm thinking we can pick one up at an auto wrecker.
Roy
2Back to top Go down   Replacement Fuel Pump Empty Re: Replacement Fuel Pump Wed Nov 04, 2015 6:03 pm
G'day Roy.
Use the Search function to find what you are looking for. There are a few posts about replacing the fuel pumps.
Here's one to start you off.
Come back to us if you have and questions.
3Back to top Go down   Replacement Fuel Pump Empty Re: Replacement Fuel Pump Wed Nov 04, 2015 7:58 pm
4Back to top Go down   Replacement Fuel Pump Empty Re: Replacement Fuel Pump Wed Nov 04, 2015 8:12 pm
This is timely as the fuel pump in the RS crapped itself on the way home on Tuesday.
Thanks for the link Rick. I've bought one so I'll install it when it gets here and report back if there are any issues.
Last edited by blaKey on Wed Nov 04, 2015 8:13 pm; edited 1 time in total (Reason for editing : the usual...schpelling.)
5Back to top Go down   Replacement Fuel Pump Empty Re: Replacement Fuel Pump Wed Nov 04, 2015 8:14 pm
:BW:
6Back to top Go down   Replacement Fuel Pump Empty Re: Replacement Fuel Pump Wed Nov 04, 2015 10:10 pm
Or this one as Rick mentioned in a previous post, out of Melbourne.
http://www.ebay.com.au/itm/EFI-FUEL-PUMP-REPLACES-BOSCH-0580464070-VL-COMMODORE-3-0L-TURBO-NON-TURBO-/121050762243?pt=AU_Car_Parts_Accessories&hash=item1c2f300c03
Only problem is that it requires one of them "pillow" filters on the inlet.  As it is 10mm they are a bit hard to find.  I scrounged one from a friend as usually they come with the pump.  The filters at EME are a larger size.
$70 delivered to your door in a couple of days.
7Back to top Go down   Replacement Fuel Pump Empty Re: Replacement Fuel Pump Wed Nov 04, 2015 10:38 pm
One mo' thing...
Can you take the pump out and then disconnect the electrical wires or is it an "in-tank" job?
I really don't want to undo small bits inside the tank with my fat hands!
8Back to top Go down   Replacement Fuel Pump Empty Re: Replacement Fuel Pump Wed Nov 04, 2015 11:11 pm
Stand down everyone, I have found the answer to my question.
You can remove the pump and then disconnect the wires.
9Back to top Go down   Replacement Fuel Pump Empty Re: Replacement Fuel Pump Tue Nov 10, 2015 7:27 pm
My new 52mm fuel pump has arrived. Looks identical to the old one. I'll swap them soon...maybe get a couple of photos, just to keep you lot interested.
Statement: I'll use the tools in my toolkit, just to see if I need additional/different tools when I'm out on the road and I need to replace the pump.
Question: Now, the pump is susceptible to rust or corrosion. Is there any special packing that I need to do if I carry a spare pump in my pannier, bearing in mind that it may be a few years (fingers crossed) before I need it?
10Back to top Go down   Replacement Fuel Pump Empty Re: Replacement Fuel Pump Tue Nov 10, 2015 7:53 pm
I have had 2 used good pumps start leaking (as in lots of the stuff) after they were sitting for a while. Once the rubber seal around the top is out of contact with the fuel it shrinks and as soon as it is started fuel pours out the top of the pump. I carry a spare pump but a new one that has never had contact with fuel.  I do think that age has a big bearing on the shrinking O-ring.
