1Back to top Go down   K1100 front disk alternatives? Empty K1100 front disk alternatives? Fri Nov 20, 2015 7:52 pm
floyd
floyd
Any gurus know if there are front disks/rotors from other makes that will fit the k1100?
2Back to top Go down   K1100 front disk alternatives? Empty Re: K1100 front disk alternatives? Fri Nov 20, 2015 9:11 pm
3Back to top Go down   K1100 front disk alternatives? Empty Re: K1100 front disk alternatives? Fri Nov 20, 2015 10:05 pm
floyd
floyd
Thanks robmac.
I actually meant are there any from other bikes, such as suzukis for example, that will fit...so I have more options on the 2nd hand market...
I highly doubt it but ya never know....
4Back to top Go down   K1100 front disk alternatives? Empty Re: K1100 front disk alternatives? Fri Nov 20, 2015 10:11 pm
Sorry, thought you meant makes other than BMW for BMWs.
5Back to top Go down   K1100 front disk alternatives? Empty Re: K1100 front disk alternatives? Sat Nov 21, 2015 4:24 pm
Floyd -TWB aka Dazza aka GiTH has Suzuki somethings on his RS but A.F.I.K. He has a bigger k75 front hoop and possibly k1100 front brakes. Do a forum search on Suzuki disks and you might find more.
K1100 front disk alternatives? Ir-log1188....May contain nuts!K1100 front disk alternatives? Ir-log11
K75RTP - 1994
6Back to top Go down   K1100 front disk alternatives? Empty Re: K1100 front disk alternatives? Sat Nov 21, 2015 6:55 pm
floyd
floyd
88KE wrote:Floyd -TWB aka Dazza aka GiTH has Suzuki somethings on his RS but A.F.I.K. He has a bigger k75 front hoop and possibly k1100 front brakes. Do a forum search on Suzuki disks and you might find more.
Thanks 88KE - I recall that also - which is what got me thinking and led me to ask the question. Forum search under way Wink
I think it may be that he has Suzuki m/c as well - ill have a dig around.
FYI ive got a complete K1100 front end on my K100 complete with the 18" 1100LT wheel.
7Back to top Go down   K1100 front disk alternatives? Empty Re: K1100 front disk alternatives? Sun Nov 22, 2015 1:18 am
AFAIK there are no other matches for the K1100 except the R1100 which is the same part number.
The Suzuki discs TWB has are bolted to a K100/K75 front wheel and have spacrs for them so K1100 four pot calipers can be used.
Best price I got was from James Sherlock in UK
8Back to top Go down   K1100 front disk alternatives? Empty Re: K1100 front disk alternatives? Sun Nov 22, 2015 8:29 am
An example of the adaption you're going to have to do is demonstrated on Kbikes built by Romestant Design.  The original Beauty used 2-pot Brembo calipers on machined spacers fitted to K75S forks and standard 305mm floating disks. The MC is a 20mm unit. The adapters space the caliper away from the forks and centered over the disks (because they would not fit if tried to attach directly to the caliper mounting lugs).  Apparently, Larry likes the brake lever feel with the weaker calipers & master cylinder combination.
K1100 front disk alternatives? Caliper%252520adapter
If you can locate a Suzuki/Yamaha/Honda rotor with the correct 6-arm pattern and bolt circle diameter, adapting Brembo or other calipers should be a matter of machining the correct adapter plate I should think.  So, any decision to go to other makes based on lower costs and/or greater availability will have all the advantages gobbled up in the costs and time associated with trying to adapt the rotor to the braking system.
