Number of posts : 7969
brickrider2 wrote:Well, that didn't work out as I had hoped.
I did the reset procedure but the ABS lights continue to blink at me. Now I have a new mystery. When I use either brake that red triangle blinks once faintly, then remains dark. All the bulbs in the brake and indicator circuits are lighting on command.
Since all was working splendidly before I went on vacation, the battery remains suspect. Even though it's far less than one year old, from day one it seemed to discharge far faster than it should. Maybe it's time for a load test. On the other hand, the bike starts immediately at the touch of the button. I'd think that a battery weak enough to cause an ABS problem would also struggle to turn over the engine on my 1996 K1100LT.
I really dislike electrical mysteries.
My K1100LT took to doing this too. Bulb contacts were the problem. Bulbs were good, but the bulb holders needed to be cleaned and the contacts tightened up. In the end I swapped out the bulbs and the problem disappeared. also clean the loom to bulb holder spade contacts.
You also mention the battery discharging fast. ABS faults can sometimes do this. Your clock remains live but the draw is minimal and I have left a bike 6 -8 weeks without a bother. Do the battery test and see how that works. But if that's ok I would remove the fuses pop in a meter to check for a heavy draw and remove the relays one by one. If one is faulty you will see an immediate drop in the current draw.
1971 Yamaha 125 YAS-1
