1Back to top Go down   ABS Light Blinking Empty ABS Light Blinking Wed Oct 28, 2015 11:46 am
piseth
piseth
Dear All,
My ABS light keeping Blinking when on the move. Used the switch to stop blinking. But it always comes on after a while. Any idea what is the problem behind the blinking of both the ABS indicators? What should i do to solve this problem as i know if the lights are blinking, then there will be no ABS to it. Really like to know the cause of it as i cant find it in the user manual. Thanks in advance
Laughing Laughing Laughing
K100 RS 1990 December
Last Location: Japan
Current Location: Cambodia
vin:0201460
2Back to top Go down   ABS Light Blinking Empty Re: ABS Light Blinking Wed Oct 28, 2015 12:04 pm
First of all, put your bike year and model description in your signature line below so we know just which bike you're asking about, since there are changes and progressions from year to year and model to model.
Errant ABS flashes are often caused by low battery voltage on ABS1-equipped K bikes. If you ride a kilometre, stop, switch off the bike, then restart, does it go out? Check the battery's voltage with a multimetre, see if it's about 12.6V when static (engine off) and 13.5 to 14.2V when running at about 2,000 RPM or greater.
You have 'normal' hydraulic brake action if the ABS is not working, at least.
3Back to top Go down   ABS Light Blinking Empty Re: ABS Light Blinking Wed Oct 28, 2015 12:49 pm
piseth
piseth
Thanks. It never go off since.i bought the bike till now.
Model k100rs year 1990 december
vin:0201460
4Back to top Go down   ABS Light Blinking Empty Re: ABS Light Blinking Wed Oct 28, 2015 8:20 pm
You have the ABS1 so if you go to Tosi Tabuki's web site all will be revealed http://bmwk10075abs1fix.web.fc2.com/
5Back to top Go down   ABS Light Blinking Empty Re: ABS Light Blinking Wed Oct 28, 2015 11:41 pm
piseth
piseth
Thanks Rick G
vin:0201460
