1Back to top Go down   Injector cleaning kit Empty Injector cleaning kit Sun Jun 11, 2017 11:09 am
I usually use a syringe barrel and pressure can to clean injectors but just found this on ebay which should make it a bit easier.
I'd swap the 12v battery clips for a 9v battery connector with a push button 'momentary' switch.
 Injector cleaning kit Austra12    Fuel:  95 Octane
2Back to top Go down   Injector cleaning kit Empty Re: Injector cleaning kit Sun Jun 11, 2017 9:10 pm
I am in no way recommending that you use my method. However I have had good results cleaning my injectors using a $20-30 Aldi ultrasonic jewelry cleaner. I fill it with injector cleaner and cycle the injectors with a 9v battery and long long leads, I use extreme care not to create any sparks. Cleaner + Sparks = Bigga Boomba.
3Back to top Go down   Injector cleaning kit Empty Re: Injector cleaning kit Mon Jun 12, 2017 2:13 am
Thanks Holister, I've ordered one just to see what they're like.
Agree with the 9v and the switch.
