Number of posts : 7968
Go for the relays and improved wiring as RickG has said.
Also, you can get a ceramic H4 bulb holder and upgrade the bulb. Ceramic H4 bulb holders should be easy to get and they resist the higher temperatures if you are running long night time trips on full beam, especially if you fit a 130 or 160W H4 bulb. Don't even think of using a higher wattage bulb without the wiring/relay/bulb holder upgrade as the extra current and heat is too much for the handlebar switch and wiring.
1971 Yamaha 125 YAS-1
