1Back to top Go down   Front indicator connector Empty Front indicator connector Sat Sep 05, 2015 2:01 pm
Zitman
Zitman
Hi all,
I have recently purchased a K100 and I have just knocked off the right hand front mirror, now I have re-fitted it OK but the wiring has been bodged and is difficult to rconnect so I was wondering if anyone could tell me the type of connector used so I can find a replacement.  I am in the UK.
Z
2Back to top Go down   Front indicator connector Empty Re: Front indicator connector Sat Sep 05, 2015 8:32 pm
AFAIK you cant buy the same connector. There was a discussion a few months ago about that connector but I cant remember what the outcome was and even if there was an outcome. The closest I could think of that will do the job is a 2.8mm spade connector.
3Back to top Go down   Front indicator connector Empty Re: Front indicator connector Sun Sep 06, 2015 8:42 am
As you have problem with the indicator connector after knocking of the mirror I assume that you have a RS.
And if so:
Female connector, part # 61 13 1 371 607.
Connector housing, part # 61 13 1 369 229.
4Back to top Go down   Front indicator connector Empty Re: Front indicator connector Mon Sep 07, 2015 12:44 pm
Zitman
Zitman
Thanks guys,
I will track some of those down.
Z
5Back to top Go down   Front indicator connector Empty Re: Front indicator connector Mon Sep 07, 2015 2:15 pm
The connector in the mirror pods is the same as the brake/clutch switches.
6Back to top Go down   Front indicator connector Empty Re: Front indicator connector Mon Sep 07, 2015 2:45 pm
sidecar paul wrote:The connector in the mirror pods is the same as the brake/clutch switches.
Front indicator connector 112350  +1.
7Back to top Go down   Front indicator connector Empty Re: Front indicator connector Tue Oct 06, 2015 4:17 pm
JaseYPK
JaseYPK
Hey mate, I'm not using standard mirrors or indicators on my RS, so I can spare you the connectors if you want them? I've only got the main "loom side" of the connectors, I haven't got the mirror/indicator side of the connectors though.
If thats any help?
1984 K100 RS - The Project!
