Number of posts : 7967
Hi Chris
Welcome to the forum and you are in the right place.
Little more information needed on which model, if you can pop your VIN and year into your signature it makes things easy for anyone offering advice as there are different engines etc on the K over the years. Early K100RS has 8 valve engine, later ones are 16 valve so a photo is even better.
Even though you have the K a while have a look at the home page and what to do if you have just bought a K. There are important things here like checking electrical connections and in particular the earths which being old bikes are very subject to corrosion and excessive electrical resistance.
All in all a great bike but they have quirks and generally these are all well known. With the advice of the forum most are usually easy enough to sort.
Before you go buying Hall sensors there is a test as in using a hair dryer to warm up the T cover at the front of the engine. The Hall sensor does sometimes fail but its more usually after heating up so this replicates the conditions. I think too it usually causes a cut out rather than poor running but am open to correction on that. Do it when engine is cold and warm the Hall sensor cover up well.
If you don't know too much of the history fuel filters are also a weak point in that they are often neglected, getting blocked and causing fuel starvation.
Early model Ks as in up to 85 have an electrical 4 pin plug connector into the bottom front left of the fuel tank. This can give trouble with poor or intermittent contact with loss of fuel pressure. Its worth a check, if it very loose you can squeeze up the female side on the plug so you get a tighter connection on the tank.
Early coils are also not the best and these can be changed. There are only two coils so you could lose one coil and be down to 3 or 2 cylinders depending on the nature of the problem. If you can work out from exhaust header temperature which cylinders are your problem simply swap the coils and if the problem moves then its coils, if it doesn't then you should suspect plugs/leads.
Plugs can and do break down and new plugs are no guarantee against a plug issue. Had it happen twice, both times plugs only had a few miles before failing.
Crankcase breather is small money and well worth doing anyway. At some point you should look at replacing fuel hoses as they get old and hard and will leak. Being all under pressure they will spray fuel.
Olaf.
1971 Yamaha 125 YAS-1
