1 Fuel Gauge Mon Aug 17, 2015 4:18 pm
Howard64180
OK, I decided I wanted a fuel gauge on my 1989 K100/2. Last time I had the tank off I fitted the harness for fuel and temp gauges. Then I was lucky to get a used fuel gauge off Ebay cheaply. It just needed the wires re-soldering. Before I go any further, I am sure the wires are connected correctly (searched for and found a clear picture to check).
The gauge is apparently not working on the bike. On the bench, when I connect a 9v battery across the terminals, positive to green/black, negative to brown, the gauge does not read. (The following will show it's actually trying to go backwards). If I then reverse the polarity it swings to full, then if I quickly return it to the original polarity it swings back to zero. Is this normal?
My fuel tank is roughly 2/3 full. I don't know if I'm doing this correctly, but measuring the ohms between the yellow/brown wires at the gauge end, with the gauge unplugged and ignition on, gives me infinite resistance (OL). With the fuel gauge fitted and ignition on, I have 12.2 volts at the green/black wire and just over 7 volts at the yellow.
Do you think the problem lies with the sender, or with the gauge itself? Thank you for any input.
