sj2000
sj2000
Wondering what you guys used to open the spring retainer for fichtel and sachs forks?
https://i.servimg.com/u/f18/19/19/68/98/20150718.jpg
Press down the spring retainer with a two legged bearing puller (attach the
legs at the upper triple tree).
Remove the clip in the grove inside the stanchion.
sj2000
sj2000
Inge K. wrote:Press down the spring retainer with a two legged bearing puller (attach the
It looks like I need to buy one then. Thanks Inge.
sj2000 wrote:It looks like I need to buy one then.
Or make your own special tool for this, the you also can press down the spring
retainer(s) when the stanchions/fork legs removed from the bike.
Anyone has tips and trick to open this spring retainer fichtel and sach forks? Avtrek10
Snod Blatter
Snod Blatter
I had a Dad around to push a T bar down into the bolt while I plucked the silly circlip out. Do you not have any help available?
sj2000
sj2000
Snod Blatter wrote:I had a Dad around to push a T bar down into the bolt while I plucked the silly circlip out. Do you not have any help available?
Unfortunately not, I will but that bearing puller.
I have just done a pair today I pushed down with a 12mm bar and picked the clip out with a fine point, came out quite easily.
sj2000 wrote:Unfortunately not, I will buy that bearing puller.
... or go to Pep Boys, O'Reilly, or NAPA auto parts store and borrow a puller. These stores loan tools to home auto mechanics. Great to borrow if this is the only reason you need a puller.
