1Back to top Go down   Gearbox/Final drive oil - K75 Empty Gearbox/Final drive oil - K75 Wed Jul 08, 2015 6:18 pm
bkhK75
bkhK75
I want to change my gearbox and final drive oil but I'm not sure if I am buying the correct oil.  I can find 80W90 in GL-5 but nowhere on the bottle can I find anything referring to it as Hypoid use.  It says it is for high pressure use but I'm confused if it will actually mention Hypoid.  Help?
2Back to top Go down   Gearbox/Final drive oil - K75 Empty Re: Gearbox/Final drive oil - K75 Wed Jul 08, 2015 7:09 pm
Howard64180
Howard64180
Had me going there for a minute - 'what I have put in mine?'.
Anyway, you'll probably find this helps:
http://www.lubetrak.com/newsletter/jan10html.html
3Back to top Go down   Gearbox/Final drive oil - K75 Empty Re: Gearbox/Final drive oil - K75 Wed Jul 08, 2015 7:48 pm
GTJos
GTJos
Very Happy Hi !
Just a week ago I changed my gear- and finaldrive-oil. (K100RT, build 1987.)
Always used Putoline 80W-90 'heavy gear' API GL-5 (and never had any problem shifting; smooth as a baby's bum  Laughing)
Good luck and drive safe !
Jos
Gearbox/Final drive oil - K75 Deutch10Ich bin enge Kirchröatsjer jong; adieë wa ?! Gearbox/Final drive oil - K75 Deutch10
                                1992  K1100LT 6458188
                                1987 K100LT (RS-fairing) 0170844 + sidecar EML GT2001
                                1986 K100RS 0085647 + sidecar Velorex 562
                                1985  K100RT  0027026
4Back to top Go down   Gearbox/Final drive oil - K75 Empty Re: Gearbox/Final drive oil - K75 Wed Jul 08, 2015 9:44 pm
k75RT Keith
k75RT Keith
I use Mobil 1 and Guard Dog Moly.  It gets changed about once a year.  No troubles at all.
5Back to top Go down   Gearbox/Final drive oil - K75 Empty Re: Gearbox/Final drive oil - K75 Thu Jul 09, 2015 10:25 am
bkhK75 wrote:I want to change my gearbox and final drive oil but I'm not sure if I am buying the correct oil.  I can find 80W90 in GL-5 but nowhere on the bottle can I find anything referring to it as Hypoid use.  It says it is for high pressure use but I'm confused if it will actually mention Hypoid.  Help?
GL-5 is a hypoid oil so you're good to go with that 80W90.
The only other question is whether you use mineral, synthetic or a semi.
 Gearbox/Final drive oil - K75 Austra12    Fuel:  95 Octane
