1Back to top Go down   The weird gets weirder Empty The weird gets weirder Mon 8 Jun 2015 - 21:47
Hairball
Hairball
Here's the blow-by-blow...('85 K100 RT w 24,000 mile - barely broke in)
  • Replaced injector O-rings to attempt rough running at 35-4500 rpms.
  • While still on the lift, I attempted to start the bike to check for fuel leaks or other badness.
  • Fuel pump worked, starter would not engage.
  • Determined that neutral switch wasn't closed (even though the green neutral light was on)
  • Wiggled shift lever
  • Bike starts!  Runs Good! Very Happy
  • Went to ride home.
  • Attempted to start bike.
  • Green neutral light was on.
  • Pulled clutch.
  • Bike Starts!  Runs Good! Crying or Very sad
  • Stopped for gas on the way home.
  • Pulled clutch.
  • Bike doesn't start! Mad
  • Decided to panic, use foul language, honk horn, push buttons, etc.
  • Get home and switch off ignition key and kill switch.
  • Headlight and Instrument cluster lights remain on, everything else switches off. :suspect:
  • Attempt to restart bike.
  • Pulled clutch.
  • Bike doesn't start! Evil or Very Mad
  • Switch off ignition key and kill switch. Headlight and Instrument cluster lights remain on, everything else switches off
  • Pulled ALL the fuses.  Headlight remains on.
  • Disconnected the battery.
  • Headlight goes out (thank god).
  • Went inside and prepared cocktail and this post.  🤡
I think I either need a new headlight or voltage shedding relay...or a priest...or put the old O-rings back in???
Any thoughts out there from folks you may have gone down this path before?
Thanks in advance!
2Back to top Go down   The weird gets weirder Empty Re: The weird gets weirder Tue 9 Jun 2015 - 4:14
walfish
walfish
Your starter motor needs an overhaul, remove it and replace brushes. Search for it using google, there are many posts.
Not a difficult task at all.
The weird gets weirder 22936
The weird gets weirder Uk-log10
                            88 K 100  0033026 (gone)
                            92 K 1100 LT  6455097 (gone)
3Back to top Go down   The weird gets weirder Empty Re: The weird gets weirder Tue 9 Jun 2015 - 6:22
Hairball
Hairball
The headlight-bone is connected to the starter-bone????
I read some of the posts regarding the issue, and the odd symptoms that arise from a crudded-up starter-bone...but the headlight not shutting off???
I will do this thing and report back...
Nick (Hairball)
4Back to top Go down   The weird gets weirder Empty Re: The weird gets weirder Tue 9 Jun 2015 - 13:35
  • Headlight and Instrument cluster lights remain on, everything else switches off. The weird gets weirder Suspect
This is most probably the ignition switch. It has 3 circuits. Parking lights, running lights and ignition systems.
It is a known problem which can be fixed with a little maintenance. It just gets a bit dirty and a little worn.
http://www.eilenberger.net/K75S/IgnitionSwitch/
 The weird gets weirder Austra12    Fuel:  95 Octane
5Back to top Go down   The weird gets weirder Empty Re: The weird gets weirder Sun 14 Jun 2015 - 8:03
Hairball
Hairball
Thanks to you both (down-under and up-over) lifetime forum members.
I completed the starter motor and ignition switch maintenance today, und alle ist in ordnung...so far anyway, it was a nice day so I left the K at the shop a rode the 63 R home.
Very Happy
6Back to top Go down   The weird gets weirder Empty Re: The weird gets weirder Sun 14 Jun 2015 - 9:30
I would be replacing the load shed relay as well, it was sticking when the lights stayed on and those bosch relays are usually very good but once they stick they only get worse.
