svlwolf
svlwolf
I changed my 85 K100RS bars out for K1100LT bars and cables, I went to mount the cable on the handlebar end and the "chain hook" is too small for the LT connection, the RS throttle end was smaller, what can I do?
K1100LT cable on left and RS cable on right
New Problem different area!! Small problem though 20150519
chain hook below
New Problem different area!! Small problem though 20150520
1985 K100RS amidst customization bounce
New Problem different area!! Small problem though Usa-lo10
The K1100 throttle cable is different because the hand piece is more like a conventional motorcycle throttle and doesn't have the chain set up. You will need to use a K100LT throttle cable. It's not practical to use the K1100 throttle as it mates up with the master cylinder which is different because the K1100 has 4 piston calipers. Its a mine field.
svlwolf
svlwolf
RicK G wrote:The K1100 throttle cable is different because the hand piece is more like a conventional motorcycle throttle and doesn't have the chain set up. You will need to use a K100LT throttle cable. It's not practical to use the K1100 throttle as it mates up with the master cylinder which is different because the K1100 has 4 piston calipers. Its a mine field.
ok, K100LT throttle cable, anyone? anyone?
Thanks as always Rick G
svlwolf
svlwolf
K100LT cable on the way!!!!
