aladin1
aladin1
HELP!  I'm trying to find a part number for an O ring that fits on the auxiliary drive shaft next to the thrust washer.
In my Clymer page 123 it is shown as item 11
In my Haynes page73 it is shown as item 16
If I knew how to I would paste the exploded drawings. I have tried searching on RealOEM but the exploded drawing on that site does not show an O ring.
Come on all you brick masters out there; help out a rookie K grease monkey
When you say 'auxiliary drive shaft' are you referring to the engine output shaft, something inside the gearbox, or the actual driveshaft?
To include a www.realoem.com image simply download it as a PDF or JPG and include it in the forum the same way you would any image.
TWB he is referring to the Alternator auxiliary shaft with free wheel o ring part 12 (page 22 sect 11(engine)) of the K series repair manual) or in his case page 73 of the Haynes Workshop Manual, I cant see a size for it in either manual either.
Probably not needed but I would take it, or the part it fits to, to your local automotive trade supplier and get one to fit. O-rings are pretty standard. Just make sure you allow for any wear or compression.
 Unidentifiable part number for 84 K100RT Austra12    Fuel:  95 Octane
Played with this last night and it seems we have been copy/pasting too many images from realoem.
The right click 'save as' option is now gone
Looks like the whole thing has been redone
This site has the same parts images and you can right click to copy. To get to the M/C part tho it looks like you have to search your VIN No. It then opens at the main part page for your model.
I just right click and 'Copy image location' then all you need to do is paste the link into the add picture button here. Much quicker
Unidentifiable part number for 84 K100RT Diag_wj
The OP is looking for an O-ring that probably goes on the shaft of part#3 in the diagram above (if compared to the drawing in Clymer). BMW doesn't list this part so there is no BMW part number nor any indicated size. Kaptain's suggestion is the best -- go find an equivalent at an automotive parts store.
aladin1
aladin1
That's right robmack........the O ring fits to the alternator side of the washer/shim that is part no. 2 on the end of the shaft of part no. 3
maybe in the next image of the intermediate housing and bearing seal assembly
you might find the bit your looking for ?
Language: českýdeutschελληνικάenglishUS englishespañolFrançaisitaliano日本語한국어NederlandspolskiportuguêsрусскийsvenskภาษาไทยTürkçe汉语繁體中文
Part Search:
K589 (K100, RS, RT, LT) K 100 RT 84 (0504,0505,0514) INTERMEDIATE HOUSING/ALTERNATOR COVER
Select another vehicle > Engine > Engine block
Sponsored links
Sponsored links
Unidentifiable part number for 84 K100RT Diag_w4
Sponsored links
[th]No.[/th][th]Description[/th][th]Supp.[/th][th]Qty[/th][th] From [/th][th] Up To [/th][th]Part Number[/th][th]Price[/th][th]Notes[/th]
01BOTTOM HOUSING SCHWARZ211141461164$471.44+core
only in conjunction with
--Dowel211141460790$1.94
02Dowel211141460790$1.94
03Grooved ball bearing20X42X12111141460805$17.52ENDED, +core
04Lock Ring42X1,75107119934710$0.88ENDED
05DIAPHRAGM SPRING111141460890$3.94
06Shaft seal26X42X5,5/7111141460809$21.48ENDED
07Fillister-head screwM6X12307119919913$0.20ENDED
08INTERMEDIATE PLATE111141460728$8.58
09Padding111141460478$2.58ENDED
10ScrewM6X25X11141460752$0.60
11Alternator cover111141464637$10.13
12Bump stop111141460487$0.60
13Fillister head with washerM5X12207119919905$0.87
14Washer5,3 ZNS207119931029$0.40ENDED
14Washer5,3207119936439$0.40
15Dowel211121250717$1.87ENDED
15DowelD=8,5X9MM211121726242$1.07
Notes
  • +core = plus core charge (possibility of a return of the old part)
  • ENDED = the part has been discontinued (no longer available).
Sponsored links
Copyright © RealOEM.com
Is it possible that Clymer has it wrong. I know there are a few mistakes in the Haynes manual. Hard to believe BMW would get that wrong.
Does the o-ring serve a purpose?
However comparing the drawings, it looks like the realoem drawings are separated into two at the bearing/seal retainer plate and that's where the o-ring goes (on the shaft).... so could've been missed
Luckily my daughter knows how to scan, here is page 22 and 23 in section 11 the engine section of the bmw Repair Manual K Series.
 Unidentifiable part number for 84 K100RT Scan_210
See page 22 item 12
Here's your answer
14.0 mm x 1.60 mm.
Part number: 11 26 1 460 459 E
Thanks Nige I just wrote that into my book so I cant miss it next time Taa mate
aladin1
aladin1
Thanks Kaptain......... What a great forum and wealth of knowledge freely given. Thank you all for your advice.
Thank the guy off that link in the other forum who had the original BMW microfiche. Just lucky I was able to find it.
BMW part numbers that have an A or E after them in ETK (Elektronic Teile Katalog) are NLA (No Longer Available).
I was just in the sprag clutch/alternator drive arrangement on my K11/K12 hybrid and there's no need for an o-ring as on mine
(da bot a' dem) there wasn't a circular bit of rubber there.
Last edited by Two Wheels Better on Fri May 15, 2015 8:59 pm; edited 1 time in total
aladin1
aladin1
Two Wheels Better wrote:BMW part numbers that have an A or E after them in ETK (Elektronic Teile Katalog) are NLA (No Longer Available).
That will be why that number shows up as 'not recognised' when I try to find a supplier. Motorworks over here tried to find the part but could not help either
