1 K75 Oil/Water pump rebuild Mon Apr 27, 2015 12:37 pm
bkhK75
I am rebuilding the oil/water pump on my 1992 K75 and have a part that I have not been able to identify. It is a spacer/washer or something that was located between the slip-ring seal and the spacer bushing. it is approximately 1/8" thick and has a rubber type material in the center where the shaft goes through like a seal of some sort. It has a diameter slightly larger than the spacer bushing. I had removed the rotor (stamped type) and the spacer bushing and was in the process of removing the shaft when it fell out of the housing so it was stuck to the seal I guess. I would like to order a new one if I knew what it was. Can anybody help me? Thanks.
