1 Vibration subsequent to clutch malfunction? Sun Apr 19, 2015 8:22 am
Big G
Hi guys
Could some more experienced members offer an opinion on this please?
I have the K100RS 1990, and a week or two ago, the clutch failed to engage again when released after a gearshift, with the lever sort of stuck halfway (a lot of play). I was on my way to work in rush-hour traffic, and revved the engine a couple of times, which caused the clutch to engage again. After three or four jerky gearshifts, the clutch has been operational again, but not as "perfect" as it was before the incident.
I am also starting to experience an almost resonant vibration through the bike, which disappears when the clutch is disengaged (lever pulled in). This vibration seems to be getting worse with time.
The short answer is most probably: pull the transmission and probably replace the clutch, as I suspect something has gone wrong in my bikes bowels?
Also, I found a post with a link to an article on replacing the clutch an a K100,but cannot seem to find the PDF which the post says "is attached at the end"? Any help here please OK - came right here, have the instructions.
1990 K100 RS (2015 - Current)
2005 R1150 GS - 35000 km (2007 - 2010)
1980 R80 GS - 28000 km (2005 - 2006)
2000 F650 GS - 102000 km (2000 - 2004)
1984 Suzuki Katana 750 - 72000 km (1984 - 1986)
1982 Suzuki DR500 - 48000 km (1982 - 1984)
