1Back to top Go down   Master cylinder  Empty Master cylinder Fri Apr 10, 2015 10:08 am
Phil63
Phil63
Hi, my bike has sat unloved for 3 years and am in the process of getting her mobile again. First thing I noticed absolutely no front brakes. Dismantled MC, a lot of crud inside which was cleaned. Piston and seals look good, bore is good. Flushed system and primed with syringe through head stock tube. Tried several bleeding techniques but cannot get any pressure. Am reluctant to buy rebuild kit when all looks good, do rubbers shrink with age? Will try the o ring fix but any ideas appreciated.
2Back to top Go down   Master cylinder  Empty Master Cylinder Fri Apr 10, 2015 7:19 pm
G'day, recently had great difficulty in bleeding front MC on the 86 K100RS. Turn handlebars to left lock and put bike on side stand. Fill MC and gently tap brake lever until no more air bubbles can be seen. It worked for me but this technique won't work with ABS. Hood luck Cheers Tom
3Back to top Go down   Master cylinder  Empty Re: Master cylinder Sat Apr 11, 2015 1:58 am
WoodyAUK75
WoodyAUK75
I replaced the MC on my 93 K75s which has the brake line going into one caliper and then a copper pipe to the other one. I could not get it bled properly. I took it to the local bike shop for a power bleed, but even then it took them another half hour or so to get it right.
4Back to top Go down   Master cylinder  Empty Re: Master cylinder Sat Apr 11, 2015 4:31 am
Mossy1200
Mossy1200
I bought a Super Cheap Autos Autos bleed kit and mine took 15mins from dry. The back took 5 mins then I did my zx14r back brake which took another 10mins. Best $15 nz I ever spent.
http://www.supercheapauto.co.nz/online-store/products/SCA-Brake-Clutch-Bleeder-One-Man.aspx?pid=291149#Recommendations
It doesn't show but has a Y intersection and 2 additional short hoses to hook onto both front calipers at the same time. Leave them 1/4 open and just start pumping lever toping reservoir up as required. Its using the hose thickness to not allow as much suck back as is pumped each cycle.
5Back to top Go down   Master cylinder  Empty Re: Master cylinder Sat Apr 11, 2015 5:20 am
"It doesn't show but has a Y intersection and 2 additional short"  Difficult to do with ABS and most of the Ks that had that crossover had ABS.
6Back to top Go down   Master cylinder  Empty Re: Master cylinder Sat Apr 11, 2015 5:26 am
Mossy1200
Mossy1200
RicK G wrote:"It doesn't show but has a Y intersection and 2 additional short"  Difficult to do with ABS and most of the Ks that had that crossover had ABS.
The bleed kit has the Y intersection and hoses. Im not sure if your referring to bike or kit.
Not familiar with abs models. Do the still only have 2 bleeding nipples, one on each caliper?
Its hard for me to know whats stock as mine came with r80 4 pot calipers when I purchased the bike and aftermarket caliper adaption mounts. Its also not an ABS model.
7Back to top Go down   Master cylinder  Empty Re: Master cylinder Sat Apr 11, 2015 5:31 am
I was referring to the bike but you were apparently referring to the kit. Don't mind me I'll go have a nice kip DOH
8Back to top Go down   Master cylinder  Empty Re: Master cylinder Sat Apr 11, 2015 5:35 am
Mossy1200
Mossy1200
RicK G wrote:I was referring to the bike but you were apparently referring to the kit. Don't mind me I'll go have a nice kip DOH
All good would have been easier if the link showed the whole kit. I found the fact you could open both nipples a real bonus when bleeding and close the first one to pass fluid for a while the other side filled up then open both again to bleed it all.
I got the kit because I struggled to get my top hose fully bleed as it would pump into the large steering head reservoir and the air would rise back up into the top hose. An our and a full brake fluid bottle wasn't doing the trick manually and I think the lower clip-ons and Master cylinder height than the tube was making things worse as it the fluid needed go up and over the master cylinder height.
