1Back to top Go down   Stupid is as stupid does ... Empty Stupid is as stupid does ... Sat Apr 04, 2015 6:11 am
DeRodster
DeRodster
So I was at the last stage of tidying up the machine and
I lifted the side cover off the bench an clipped the corner off something
DAMMIT ;-(
Stupid is as stupid does ... 2015-016
any clue as to what to do ?
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
2Back to top Go down   Stupid is as stupid does ... Empty Re: Stupid is as stupid does ... Sat Apr 04, 2015 6:17 am
Glue it back, use that fast glue, the gel one.
Stupid is as stupid does ... Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
3Back to top Go down   Stupid is as stupid does ... Empty Re: Stupid is as stupid does ... Sat Apr 04, 2015 6:47 am
heres a suggestion rod
instead of trying to glue edge to edge ...(which doesn't work long time )  cut a piece of aluminium sheet that will overlap both portions (obviously to the contour of the edge section - and corner )
this will give added strength to the repair ....and possibly wont be seen from the outside ?
I have done similar ...some time ago, to the pins that hold to the back of the side cover ...no movement or fracturing has occurred since ...where as end butt repairs always seem to fail
good luck
4Back to top Go down   Stupid is as stupid does ... Empty Re: Stupid is as stupid does ... Sat Apr 04, 2015 6:48 am
Sidepanel? It looks like a clean break? Yes, Gorilla glue or similar but with one addition: glue a plate over the back of the join too so that any flex doesn't go through the join alone. Plastikard or thin aluminium will both do.
[Edit] Charlie arrived about two seconds ahead of me!!!
5Back to top Go down   Stupid is as stupid does ... Empty Re: Stupid is as stupid does ... Sat Apr 04, 2015 7:03 am
Stupid is as stupid does ... 112350
like minds  dai ? ...no matter who got in first ...conformation is always a great contribution to the help that we share amongst us all
6Back to top Go down   Stupid is as stupid does ... Empty Great minds.... Sat Apr 04, 2015 7:38 am
DeRodster
DeRodster
Gracias Amigos
I guess I should have taken more notice of the right side panel,
where the previous had done a similar, though larger repair.
Stupid is as stupid does ... 2015-017
Not sure if "Gorilla" glue is available here but two part epoxy might do the trick
and I have some light aluminium panel about somewhere.
more anon
Rod
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
7Back to top Go down   Stupid is as stupid does ... Empty Re: Stupid is as stupid does ... Sat Apr 04, 2015 7:55 am
See if you can find some Evo-Stik 'Serious Glue'. It's polyurethane-based and will have more 'give' in it for temperature expansion/contraction. Two-part epoxy will crack over time.
8Back to top Go down   Stupid is as stupid does ... Empty Re: Stupid is as stupid does ... Sat Apr 04, 2015 8:05 am
selleys or similar "gel grip" seems to work out ok
9Back to top Go down   Stupid is as stupid does ... Empty The story so far Sat Apr 04, 2015 8:21 am
DeRodster
DeRodster
Ok thank's to you all for the glue advice.
I'll have a look for something with a bit of flexibility.
and this is where I'm at now with the aluminium...
Stupid is as stupid does ... 2015-018
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
10Back to top Go down   Stupid is as stupid does ... Empty Re: Stupid is as stupid does ... Sat Apr 04, 2015 8:38 am
That's the ticket Rob. My experience of Gorilla glue is that it works well but doesn't keep, at least in the small plastic bottle making it an expensive proposition. Two pack epoxy areldite etc works well on those panels. You will need it somewhere warm in these temps tho'.
We'll see you on the road soon hopefully.
Stupid is as stupid does ... Ir-log1188....May contain nuts!Stupid is as stupid does ... Ir-log11
K75RTP - 1994
11Back to top Go down   Stupid is as stupid does ... Empty Re: Stupid is as stupid does ... Sat Apr 04, 2015 8:55 am
88KE wrote:Two pack epoxy areldite etc works well on those panels.
Stupid is as stupid does ... 112350 ...+1 ... Did use it 12 years ago on exactly the same repair.
Stupid is as stupid does ... Deksel10
Amazing stuff, over the years I have used it on engine blocks, engine
covers, fuel tanks.....and a lot more.
12Back to top Go down   Stupid is as stupid does ... Empty Re: Stupid is as stupid does ... Sat Apr 04, 2015 10:30 am
Okay, so I'm out-voted Very Happy About thirty years ago we used two-part Araldite to repair the cam tunnel in a Honda CJ250. At least ten years later it was still in there doing its job.
13Back to top Go down   Stupid is as stupid does ... Empty Re: Stupid is as stupid does ... Sat Apr 04, 2015 1:15 pm
Steve M
Steve M
Hi Rob,
I used two part Araldite on both my side panels and was very pleased with the result.
Cheers,
Steve.
14Back to top Go down   Stupid is as stupid does ... Empty Re: Stupid is as stupid does ... Sun Apr 05, 2015 4:21 am
DeRodster wrote:Ok thank's to you all for the glue advice.
good work rod that will help fix things up definately ....just glue into place
15Back to top Go down   Stupid is as stupid does ... Empty Re: Stupid is as stupid does ... Sun Apr 05, 2015 12:08 pm
DeRodster
DeRodster
Yep, got myself some Evo Stik "Serious Glue" yesto, and glued her up last evening.
amazing stuff and has some flexability , so all it back as it should be.
Thanks to all for the advice.
safe riding
Rod
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
