1Back to top Go down   Clutch assembly question Empty Clutch assembly question Tue Feb 04, 2020 1:48 am
freed
freed
I did take off my gearbox to renew clutch gaskets. I noticed that center of clutch, there some small part. In haynes manual it seems to be same level with the outer part but mine is bushed in about 10mm. Should this be fixed or what to do?
Photo for better explanation:
 Clutch assembly question Kytkin10
2Back to top Go down   Clutch assembly question Empty clutch assembly question Tue Feb 04, 2020 1:41 pm
audibob
audibob
Hi Freed,
the clutch operating rod acts directly onto the brass bush in the output shaft.
Use https://www.realoem.com/ to view the aspects of the bike , I find it very useful
Good luck
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
3Back to top Go down   Clutch assembly question Empty Re: Clutch assembly question Tue Feb 04, 2020 1:55 pm
audibob wrote:the clutch operating rod acts directly onto the brass bush in the output shaft.
The clutch pushrod pushes on the center of the clutch diaphragm spring.
4Back to top Go down   Clutch assembly question Empty Re: Clutch assembly question Tue Feb 04, 2020 2:55 pm
freed wrote: I noticed that center of clutch, there some small part. In haynes manual it seems to be same level with the outer part . . .
Use actual specifications to determine machine clearances rather than murky halftone photos shot at oblique angles. Smile
5Back to top Go down   Clutch assembly question Empty clutch assembly question Tue Feb 04, 2020 5:12 pm
audibob
audibob
Of course , what I should have said is that the end of the clutch rod fits into the brass
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
6Back to top Go down   Clutch assembly question Empty Clutch Wed Feb 05, 2020 3:35 pm
daveyson
daveyson
One option, if you don't have a suitable slide hammer, you could improvise one.
 ~120,000 km
7Back to top Go down   Clutch assembly question Empty Re: Clutch assembly question Thu Feb 06, 2020 3:55 am
freed
freed
I found these parts from local bearing shop: 6x12x12 bonze slide bearing, price was reasonable 1,25€.
Today I am trying to get old one out and sliding new one in.
I am going to make threads to the old and with bolt get it out. Lets see what happens.
8Back to top Go down   Clutch assembly question Empty Re: Clutch assembly question Wed Feb 12, 2020 3:41 am
freed
freed
freed wrote:I found these parts from local bearing shop: 6x12x12 bonze slide bearing, price was reasonable 1,25€.
 Worked well, made threads to the old bearing. With spacer and bolt, old one can be pulled away. New in by gently tapping it.
