1 Headlight woes Fri Mar 13, 2015 5:31 pm
krambo
Not quite sure what is going on with my 1984 K100 - I noticed a while ago that main beam would not function from handlebar headlight switch but dip was still working normally and I generally have dipped beam on all the time. Main beam would work if I pressed the headlight flasher switch but obviously not practical to ride holding that switch. As I normally ride with dipped beam on all the time I haven't really bothered too much about it until now because I mostly use this bike for daytime only motorcycle instruction etc. It was pointed out to me on the last training session that I didn't have my lights on! It seems that I have lost low beam too now! Today I decided to investigate further. My first thought was to try a new headlight bulb, a bit of a faff to replace the bulb and still no dipped beam or main beam but main beam flasher still works. I suspect that the main beam issue stems from the right hand switchgear for which I do have a replacement in the pipeline, as mentioned in another post. Unfortunately, I now have no low beam either ! Just the little sidelight. Anyboby got any guidance as to what I should do next ? Thanks in anticipation of your feedback etc.
"Aut viam inveniam aut faciam."
