1 Oh well! Tue Apr 09, 2013 10:19 am
MikeP
After a longish ride the other day I decided that the K1 needed a Throttle Body balance. To be honest the fuelling was never right. After any sustained runs at speed and coming to a halt in traffic or at junctions etc the revs would drop away and the engine sometimes stall.
Well with the under-tray off and the left side of the fairing removed I cracked on and discovered that a previous owner had used the BBS (Big Brass Screws) to try and balance the TBs! I discovered this when I removed them for cleaning before starting the process, one was almost at the end of its available thread!
The thing with the 16-Valve bikes is that the idle-speed adjuster isn't at all obvious unlike the 8-Valve models. The fuel rail and injectors are in a different place (as the injectors were moved to make room for the extra valves). There's no way to get in there with anything but a slim ¼ inch drive ratchet and an equally slim 7mm socket.
It's pretty hard to spot it behind the Throttle Bodies and if you didn't know it was there you might think that the BBS were the only way to alter the idle speed.
Anyway, with it all adjusted and running sweetly I left it to today to replace the panels and take it for a quick squirt up the main road to check that all was okay.
I discovered this under the bike this morning (not the screwdriver ):
I'd actually cleaned up what was there at first, the above drip took a few minutes to appear after.
As per the title - Oh well, the weather has turned to crap again so I may as well spend my time in the garage. New seals are on the way from Motobins. I was tempted to fit a new K1200LT oil/water pump - police bikes were fitted with them as the 1200LT pump gives better low speed cooling - but the price put me off.
