Number of posts : 12058
If you have the gearbox out put a new rear main seal in, it probably has never been changed.
I use a viton seal that is 8 x 50 x 80mm they will sting you for about $80 but scream like a stuck pig and say you got one for the other bike here last year for $34 and they probably will relent. If not go elsewhere and try it.
smell the oil to tell where it came from, gearbox oil has a very sulphur smell.
Final drive seal is very easy and straight forward. If the disc bolts, 2 socket head counter sunk, are difficult use heat to soften the loctite. Remove the 8 x 8mm socket screws and split the case and replace the seal taking care to make sure the running surface for the lip is good and clean. Replace the seal and making sure the O-ring and shims are in place.
Parts I usually buy from Motobins in UK but seals are available in Oz.
https://www.motobins.co.uk/
