1 Temperature Relay - Cooling fan not working Tue Mar 03, 2015 9:16 pm
floyd
Howdy Krew
My fan used to come on all the time.
A few months ago I completely flushed the cooling system several time using a cleaning product.
I also fitted a nice 3 bar radiator.
Ever since then the fan has not come on. At first I assumed it was a result of the cooling system working a lot better. But it wont turn on even when the bike is left to idle for 10-15 mins.
- The fan will come on fine when I jump the appropriate wire in the relay socket.
- the temp warning light comes on when the appropriate wires are jumped in the relay socket.
- the fan does not come on when the temp sensor wires are jumped
- There is continuity between the temp sensor and the FI computer and the relay socket
- it will not start when I ground the E wire in the relay socket (with the temp sensor unplugged)
- It will not start when I ground the temp sensor wire
- checked resistance at relay socket when hot and cold and got expected readings
So based on all that, the fan is fine, the wiring is fine, the temp sensor is fine....which leaves the relay. I should have 2 spares but can not find them anywhere. A new one is $160 AUD (F%$k!!!)
Is it possible to test the relay? it looks fine on the inside and the contacts are not fused shut.
Am I missing anything else?¿?¿
