1Back to top Go down   Clutch Plate thickness Empty Clutch Plate thickness Sat Feb 07, 2015 9:29 pm
ShedBob
ShedBob
Pulled the transmission out of my 1985 K100RT today. The clutch splines have never been lubed so I thought it was probably about time.
Looking at the clutch plate it measires 5mm across the friction surfaces. The Haynes manual says 4.5mm is the wear limit but mine is nearly on the rivet heads.
Wondering how thick a new one is ?
Really I'm just wondering if I should just replace the plate so it's good for another 30 years.
2Back to top Go down   Clutch Plate thickness Empty Re: Clutch Plate thickness Sat Feb 07, 2015 9:34 pm
ShedBob wrote:Wondering how thick a new one is ?
5,5 mm.
3Back to top Go down   Clutch Plate thickness Empty Re: Clutch Plate thickness Sat Feb 07, 2015 10:28 pm
ReneZ
ReneZ
You're in there now, so renew it. Also do the engine output shaft seals and live happily ever after :-)
Rene
BMW K100 - 1985 (0030029) Scotland Clutch Plate thickness Rain
4Back to top Go down   Clutch Plate thickness Empty Re: Clutch Plate thickness Sun Feb 08, 2015 5:49 am
+1 to ReneZ.
As a licensed mechanic I used to do a lot on cars. My rule of thumb was that if the engine and gearbox were separated, unless I had certain knowledge of a new clutch being put in recently, I put in a new one.
I haven't had my K apart that far yet, but when I do, I'll be doing what ReneZ has suggested.
5Back to top Go down   Clutch Plate thickness Empty Re: Clutch Plate thickness Sun Feb 08, 2015 11:17 am
ShedBob
ShedBob
Yeah I'd pretty much decided to put a new plate in anyway as it's such an awful job to get in there.
Don't want to do it again in a hurry.
6Back to top Go down   Clutch Plate thickness Empty Re: Clutch Plate thickness Sun Feb 08, 2015 11:24 am
ShedBob wrote:Don't want to do it again in a hurry.
Exactly why I always changed it.  Smile
7Back to top Go down   Clutch Plate thickness Empty Re: Clutch Plate thickness Sun Feb 08, 2015 1:00 pm
ReneZ
ReneZ
It's not only the plate thickness that's important. How are the splines??
Rene
8Back to top Go down   Clutch Plate thickness Empty Re: Clutch Plate thickness Mon Feb 09, 2015 8:36 pm
ShedBob
ShedBob
Splines are good Rene.
Alternator shaft seal is away though.
