Number of posts : 7969
Batteries can be tricky. When I got the LT I did quite a bit to it and the battery was checked as being ok.
6 weeks later up the west of Ireland on a Friday morning no go and not a motorcycle shop never mind a BMW one anywhere. Battery kaput. Anyway my only option was a ride on lawnmower outlet about half an hour away. Not expecting much I took the old battery with me and put up on the counter with a timid 'would you have one of these?' The man reached under the counter and lifted up a battery 'you mean like this?'. A perfect fit and all problems solved. My car was the same, anything dodgy on the battery and all would go mad. Usually the dealer charge for the diagnostics to tell you the battery is kaput is more than the cost of a battery. Lawnmower battery as dirt chap and it performed perfectly.
RickG is very right about a low battery.
If you can do it and haven't already done it you should open every electrical connection and clean it up. That includes the earth points. Its easy to do without the wiring diagrams if you take it methodically one connection at a time. With age they get corrosion and deposits on them that act as insulators. Clean up all the connections at the ICU unit under the seat and up at the headstock at the front of the gas tank. Dodgy connections can make a good component or sensor appear to be faulty so it is very important to get these sorted before going down the road of replacing too much. There are plenty of recommendations about fitting headlight relays rather than run the current through the switch, this may have been done by a PO. Also most important that brake fluid is changed regularly as the ABS units don't like lack of maintenance.
If you haven't done it you should replace the high pressure fuel lines as they perish with age. Same with brake pipes. Tyres go hard and horrible, 5 years is tops and 3 years better. Some bits actually suffer more from lack of use because of a lack of constant movement and corrosion.
1971 Yamaha 125 YAS-1
