1Back to top Go down   Fuse box Empty Fuse box Sat Dec 27, 2014 1:51 pm
andy1141
andy1141
Hello
K100rt I wanted to know do you have to remove the tank to get inside fuse and relay box.
Someone has wired up the fourth fuse holder which I believe is spare and it keeps blowing fuses so I wanted to trace where it went.
I know fuel gauge dosnt work I've looked in tank and its corroded. Also I don't think the smaller aux sockets don't work either
There is also a small switch just above dash board light I havent a clue what's that for .
Any ideas thanks andy
2Back to top Go down   Fuse box Empty Re: Fuse box Sat Dec 27, 2014 2:55 pm
To just change a relay it's enough to lift the tank in the rear end, but you get far
better acces if you remove the tank.
Fuse #4 is for the aux. power socket (if mounted,.....on top of the coil cover,
and/or the crashpad underneath the instruments).
3Back to top Go down   Fuse box Empty Re: Fuse box Sat Dec 27, 2014 3:54 pm
andy1141
andy1141
Thanks for that .
I thought you did. It's not effecting anything else so I will look at wiring when I atempt the the fuel gauge .
Andy
