1Back to top Go down   Footplate Konfusion Empty Footplate Konfusion Mon Dec 29, 2014 6:14 pm
Kyle10
Kyle10
So, in a excitable state I find a pair of footplates on fleabay that match, to replace a broken right side with a 'new' set.
They arrive intact, so on to the powdercoating shop for a satin black finish. Got them back, marveled at how good they look and, lo, when I went to mount them on the trans/drivetrain I notice...BIG holes, where my originals ('85rt) have waaay smaller holes.
As Sir Guinness said,
Footplate Konfusion Footplate1_zps0a327ab1
Footplate Konfusion Footplate3_zpsea592e4f
Why are these holes so big? Are these from the ill-fated rubber mounted days?
1985 K100rt 0052183
1983 Honda VF750 007713
2Back to top Go down   Footplate Konfusion Empty Re: Footplate Konfusion Mon Dec 29, 2014 6:27 pm
This is the rubber mounted version which was used most of the time -83 -85.
Solid mounted was used a short period before the -86 on with a different design.
3Back to top Go down   Footplate Konfusion Empty Re: Footplate Konfusion Mon Dec 29, 2014 6:27 pm
Kyle10
Kyle10
Thanks Inge.
Found 'em but w/no part number. Where in the aych am I going to find these??
Footplate Konfusion Footplatemounts_zps25c9f105
1985 K100rt 0052183
4Back to top Go down   Footplate Konfusion Empty Re: Footplate Konfusion Mon Dec 29, 2014 6:35 pm
Search the rubbers and big washers....is what I would have tried.
5Back to top Go down   Footplate Konfusion Empty Re: Footplate Konfusion Mon Dec 29, 2014 6:47 pm
Kyle10 wrote: Found 'em but w/no part number.
That is the ekshaust mount, not shure if they are similar.
6Back to top Go down   Footplate Konfusion Empty Re: Footplate Konfusion Mon Dec 29, 2014 6:54 pm
Kyle10
Kyle10
Great. I'm envisioning desperate/creative fishings through endless bins at the local hardware store to replicate this:
Footplate Konfusion Footplatemounts3_zpsef2f35db
Footplate Konfusion 259495
1985 K100rt 0052183
7Back to top Go down   Footplate Konfusion Empty Re: Footplate Konfusion Mon Dec 29, 2014 6:57 pm
You find them under euro models......here.
It's the same parts as the ones used for the ekshaust mount.
8Back to top Go down   Footplate Konfusion Empty Re: Footplate Konfusion Tue Dec 30, 2014 3:40 pm
Kyle10
Kyle10
Inge K. wrote:You find them under euro models......here.
Thank you Inge. You're talking me off the ledge. Can you tell me which part #'s I'm needing for 2 plates?
Footplate Konfusion Footplatemountparts2_zpsc5b449f2
Footplate Konfusion Footplatemountparts1_zpsb84e940f
1985 K100rt 0052183
9Back to top Go down   Footplate Konfusion Empty Re: Footplate Konfusion Tue Dec 30, 2014 4:38 pm
You will need 6 pc. of each from #2 to #9. The spacer is NLA, use one from
the ekshaust mount as a template and make your own ones.
Don't know why the most forward spacer is different, I'll guess you gonna find
out when fiddlin with the parts.
10Back to top Go down   Footplate Konfusion Empty Re: Footplate Konfusion Tue Dec 30, 2014 6:29 pm
Just to throw a bit more Konfusion into the pot, the rubber mounted footrest plates used footrests with bolt-on end weights.
11Back to top Go down   Footplate Konfusion Empty Re: Footplate Konfusion Tue Dec 30, 2014 7:11 pm
Kyle10
Kyle10
sidecar paul wrote:Just to throw a bit more Konfusion into the pot, the rubber mounted footrest plates used footrests with bolt-on end weights.
Stay outta this, dammit  Laughing
What do you mean? Think I can jimmy up a substitute?
1985 K100rt 0052183
12Back to top Go down   Footplate Konfusion Empty Re: Footplate Konfusion Tue Dec 30, 2014 10:08 pm
Mossy1200
Mossy1200
I had a set but can only find one rubber now. Its likely I gave them away with the fairings as I sent the guy everything that looked like mounts.
You could lathe up replacements from Teflon or Ally.
Maybe contact BSK speedworks as they may have some from the bikes they are converting with their rearsets.
13Back to top Go down   Footplate Konfusion Empty Re: Footplate Konfusion Sun Jan 04, 2015 2:43 am
Paul aren't they called hero nobs?
