1 Inside of a fuelpump and the pressure regulator Thu Dec 25, 2014 1:44 am
Thanks to the new kind of fuel we have here, and the fact that the bike has been left alone for a year, the problem of too high fuelpressure let my K run like a drunk.
Reading about every interesting topic here, Sidecar Paul mentioned about a regulator in the pump itself.
Took te pump out, and found the bugger.
Now will share my pictures from the inside of the pump;
This is the actual pump without the motor, before you take it apart, mark some things that everything goes exactly back to where it has been before;
Here is the regulator from the inside, if it's stuck, push it gently with a soft tool down. I took the cap of a BIC-pen.
Here it is on the outside, if you don't open the pump, and have a small telephone pliers, you can pull the pin in the middle;
Before cleaning;
After cleaning;
Put the pump back together, the O-ring goes in first in the aluminium can, then the pump;
Watch out removing the 2 clips wich hold the motor in place, they are not easy to find when they try to escape, and hard to get in the open world (store)
Before cleaning;
After cleaning;
K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
