1Back to top Go down   Acewell 2853 questions again Empty Acewell 2853 questions again Tue Nov 18, 2014 8:55 am
Raf-1200
Raf-1200
Sorry to start another thread on the 2853 acewell but the others are quite old with past members no longer being on etc.
Green black (6) is supposed to be power 12v correct on the gauge connector. I'm not getting any reading. Any ideas?
I've checked the fuses.. I figure there is something simple when you are in the know:0
Last edited by Raf-1200 on Tue Nov 18, 2014 9:00 am; edited 1 time in total (Reason for editing : not enough info)
2Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Tue Nov 18, 2014 9:11 am
Brakelight is in the same circuit, does it function?.....with the ignition switched on.
3Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Tue Nov 18, 2014 9:20 am
Check the fuses with a meter not just a visual check. Those blade type have a habit of going open circuit and still looking OK.  I have been caught in the past and others I know also have so it's always worth a check.
4Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Tue Nov 18, 2014 9:29 am
To get power to fuse #1 also the kill switch must be in the on position.
5Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Thu Nov 20, 2014 12:54 am
Raf-1200
Raf-1200
Well this is embarrassing..... Thanks Inge;)
So now that problem is sorted. I'm onto the relays. Also going with led indicators so have to install resistors in the line.
6Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Thu Nov 27, 2014 7:47 am
Raf-1200
Raf-1200
Still headaches! I've wired up my relays into a neat little box.
The indicators work and the high beam work.
Oil light works
Neutral light does work but STAYS ON through all gears:/
I've done the fuel relays as well but not a huge deal if it's not working yet....
So purple goes to relay 4. 30 position. This is the neutral light. Any ideas why this might stay on?
7Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Thu Nov 27, 2014 7:51 am
Raf-1200
Raf-1200
As an explanation to the rest I've put
Orange - 19
Light green - 15
Grey - 11
White - 17
Black - 13
Brown - 1
Blue - 7
Not worrying about hazard so have done nothing with light blue
8Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Thu Nov 27, 2014 11:39 am
About neutral always on, I would guess that you have done something wrong
when wiring the relays.
But a shorted clutch switch and a incorrect mounted diode also can cause this.
About Blue - 7, this is for a fuel level indicator on the Acewell, on your -84 you
don't have a fuel level sensor......
9Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Thu Nov 27, 2014 8:25 pm
Raf-1200
Raf-1200
I think you may be right Inge. Tell me, on the 4 relay schematic that is floating around about this, the top diamond says switched power 12v+.
I've connected all 4 wires (the 3 86's from the first 3 relays) to the 30 from the first relay and hooked that all up to green/black at pin 5.
Is that right?
10Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Thu Nov 27, 2014 9:07 pm
30 on the fourth relay should be connected to purple wire to the Acewell.
86 on the fourth relay should be connected to 87 on the third relay before the diode.
85 and 87 on the fourth relay should be connected to ground.
11Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Thu Nov 27, 2014 9:25 pm
Raf-1200
Raf-1200
ahha. 86 before the diode? What diode?
[url=[/url]">Acewell 2853 questions again K100relayorientation_zps24e68637
12Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Thu Nov 27, 2014 9:28 pm
Raf-1200
Raf-1200
[url=[/url]">Acewell 2853 questions again K100relaydiagram_zpse9c10742
13Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Thu Nov 27, 2014 9:29 pm
Raf-1200
Raf-1200
I haven't put the diode in... that could be my mistake:/
Can you look at the first photo Inge and tell me if the rest looks right to you?
Raf
14Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Thu Nov 27, 2014 9:35 pm
The designation codes which is written with a pen is wrong.
1 = 86
6 = 85
7 = 87
12 = 30
Is it mechanical or solid state relays? Solid state won't function.
15Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Thu Nov 27, 2014 9:46 pm
Raf-1200
Raf-1200
Ahhh Thanks. Mechanical I assume. I hear it clicking when I hook things up so I assume it's working?!
Very annoying. The numbers were written in by the guy at Jaycar so probably shouldn't base everything on the assumption that he knew what he was talking about! EVERY one wrong .. haha unbelievable
Thanks again Inge:)
16Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Thu Nov 27, 2014 9:47 pm
It should be connected to the black/green at pin 6.
At pin 5 it shouldn't be any power unless neutral is selected or clutch pulled
(or connection to clutch switch shorted).
17Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Thu Nov 27, 2014 9:52 pm
Raf-1200 wrote:I haven't put the diode in... that could be my mistake:/
The only difference it would make is that your neutral light would be on every
time you pull the clutch. (if the clutch switch still is present, of course).
18Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Thu Nov 27, 2014 9:58 pm
Raf-1200 wrote:Very annoying. The numbers were written in by the guy at Jaycar so probably shouldn't base everything on the assumption that he knew what he was talking about! EVERY one wrong .. haha unbelievable
The terminal designations used is the german DIN standard used on (most)
European vehicles, I would guess that they isn't so familiar with that on Jaycar.
19Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Thu Nov 27, 2014 10:42 pm
Raf-1200
Raf-1200
Yeeha. We have neutral!!!
Now I've put the 86's to pin 6 as you said.
I thought the black/green to start button was pin 6 so it goes to pin 5 correct?
20Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Thu Nov 27, 2014 10:46 pm
Hmmm........probably to much Tuborg green for this evening Beer drinker .
You was correct with the colour code, but wrong pin #.
Pin 5 = black/green to start button/clutch switch.
Pin 6 = green/black, switched power.
21Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Fri Nov 28, 2014 2:08 am
rapt
rapt
Raf-1200 wrote:Well this is embarrassing..... Thanks Inge;)
Instead of using resistors for the led indicators (they get hot and you have to find somewhere to mount them)
Open up the relay and cut pin 7 on the chip or use a knife and cut the track on the circuit board to break the connection.
Instructions here
http://classickbikes.com/ckb.tech/0.ckb.tech.files/ledoemflrelay/ledoemflrelay.htm
22Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Fri Nov 28, 2014 2:29 pm
Raf-1200
Raf-1200
Yep and now it works like a dream. Diode installed and everything. Going to box up my little unit and get my tank back in.
Thank you for all the help. I haven't had much luck with the fuel meter by the looks of it, but still stoked with the results so far. Thanks Inge
23Back to top Go down   Acewell 2853 questions again Empty Re: Acewell 2853 questions again Fri Nov 28, 2014 3:22 pm
Raf-1200 wrote: I haven't had much luck with the fuel meter by the looks of it,
Have another look at reply #8.
