1Back to top Go down   Oil/Water Pump - Oil Pressure Switch Empty Oil/Water Pump - Oil Pressure Switch Sat Nov 08, 2014 11:02 pm
G'day all in K Land, Still mucking around with the 86 K100RS project.(will get some photos up soon). Next to the OPS is another similar looking switch and was wondering what it is. I'm guessing it is a coolant temperature sending unit. Could all you knowledgeable people please enlighten me. Thanks heaps in advance. Cheers Tom
That sender is for a temperature gauge but has nothing to do with the ECU temp sender which is on the coolant outlet stub behind the radiator.
