1Back to top Go down   Side Stand Lean angle Empty Side Stand Lean angle Tue Mar 23, 2010 12:51 pm
Bruce
Bruce
Hello everyone!
Noticed that my sidestand seems to really lean the bike over at quite a steep angle! any ideas of how much is too much, the stands themselves seem to be ok, no play or anything. any suggestions?
2Back to top Go down   Side Stand Lean angle Empty Re: Side Stand Lean angle Tue Mar 23, 2010 1:01 pm
beachcomber
beachcomber
You mean to say you HAVEN'T got a 2" thick lump of wood in your tool kit!!!!!!!!!!
3Back to top Go down   Side Stand Lean angle Empty Re: Side Stand Lean angle Tue Mar 23, 2010 2:38 pm
Ajays
Ajays
Side Stand Lean angle Angle%20of%20BikeSide Stand Lean angle Ali%20BlockSide Stand Lean angle Wood_bike This bloke has plenty of wood to spare...!
Nylon block or wood...this is then the lean.
Ajays
Last edited by Ajays on Tue Mar 23, 2010 3:12 pm; edited 1 time in total (Reason for editing : to show lean)
4Back to top Go down   Side Stand Lean angle Empty Re: Side Stand Lean angle Tue Mar 23, 2010 4:34 pm
Hey Ajays,
your rs is wearing High heels? It would look better with pantyhose too. Very Happy
Side Stand Lean angle Frog15Side Stand Lean angle Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
5Back to top Go down   Side Stand Lean angle Empty Re: Side Stand Lean angle Tue Mar 23, 2010 6:22 pm
Ned
Ned
Smile I asked the same question from the same bunch of brick loonies and got the same bunch of answer. just kidding people.Smile Ajays machining skill are to be admired, however.
The serious answer is that you should look at removing the side stand, closing the "foked" pivot point a bit and tightening the pivot bolt.
If that does not help, as it din't in my case, I have a nylon puck (1" thick) in my jacket pocket and use it when the lean angle gets alarming.
6Back to top Go down   Side Stand Lean angle Empty Re: Side Stand Lean angle Wed Mar 24, 2010 6:05 am
phil_mars
I plan a combination of Ned's suggestion and Ajays. Basically shim out the pivot to remove play. It only requires about 0.5 mm and add some sort extended foot.
I was going to try some Sellys two part metal adhesive that can supposedly be machined into screws etc once hardened.
Phil
7Back to top Go down   Side Stand Lean angle Empty Re: Side Stand Lean angle Wed Mar 24, 2010 1:49 pm
Bruce
Bruce
Wow, bike does look sexier with the heels tho! needs fishnets too! I'll try the fix on the stand, and head to the high heels if that doesn't work. thanks all! cheers B
8Back to top Go down   Side Stand Lean angle Empty Re: Side Stand Lean angle Thu Mar 25, 2010 4:18 am
Ajays
Ajays
Bruce,
Mine is Ali held with two allen screws.
Just one point, it needs to be cleared aways as you can see to clear the centre stand otherwise you can't use the prop stand if its up when the centre stand is used.
Ajays
Side Stand Lean angle Th_Kengine_gif
AJAYS
9Back to top Go down   Side Stand Lean angle Empty Re: Side Stand Lean angle Fri Mar 26, 2010 3:13 am
I have a big load spreader puck for sandy conditions with a super magnet to hold it onto the side-stand till it is retracted, once it is up I pull it off and pop it into my pocket.
K-Bike
10Back to top Go down   Side Stand Lean angle Empty Re: Side Stand Lean angle Fri Mar 26, 2010 6:34 am
The idea of the magnet is a great one. This is the first time that somebody mention it.
Thanks for the tip.
Bert
