1Back to top Go down   Front Brake Feed Pipe Empty Front Brake Feed Pipe Thu Oct 30, 2014 9:39 am
CraigNZ
CraigNZ
Just a question.  The front brake pipe on my bike feeds from behind the head-stock to the right, through a bracket with a rubber bush, fastened to the bottom yolk, and down to the split at top of the front mudguard. It looks a little odd to me although I can't see how else it could be routed. Left hand full lock is OK but right hand lock seems to put a lot of 'bend pressure' on it by the head-stock. Looks to be pretty tough (plastic?). Know the bike is rarely on full lock but is this routed correctly?
1991 BMW K100RS
1999 BMW R1100S
2Back to top Go down   Front Brake Feed Pipe Empty Re: Front Brake Feed Pipe Thu Oct 30, 2014 10:10 am
The bracket should be fastened to the radiator shroud just to the right of centre and at the top of the shroud. The ABS sensor cable should go through the same bracket and be tied to the flexible brake line which is attached to a T junction then separate lines to each caliper.
The brake line should not be attached to the triple clamp at all.
3Back to top Go down   Front Brake Feed Pipe Empty Re: Front Brake Feed Pipe Thu Oct 30, 2014 7:54 pm
CraigNZ
CraigNZ
That makes sense. The fairing is no more, It was damaged, probably find whoever fitted the bikini headlight fastened the pipe to the triple clamp.  Not a pretty picture, I have work to do (remove that tape for a start !)
Front Brake Feed Pipe Brake_10
1991 BMW K100RS
1999 BMW R1100S
4Back to top Go down   Front Brake Feed Pipe Empty Re: Front Brake Feed Pipe Fri Oct 31, 2014 12:36 am
Jez
Jez
Hey Craig,
You remind me of a good point and a chance to get on my soapbox and become the town crier against adhesive tapes.
As a Sound Tech, I have to occasionally install power or sound cables that must stay in for a while if not permanently.
Public announcement people..... " Don't use electrical tape, sticky tape and esp. Gaffa tape" on anything unless it's just to get you home and then proper repairs will be carried out.
Many of the adhesives will eat your plastics and rubbers over time, that greasy feeling of a cable that's been shrouded in tape for a year is evidence of that.
Use either heat shrink or if you can't get a shrink over your mend, then source a rubber self amalgamating tape, it's adhesive free and will stick to it's self like magic, leaving your 30 year old electrical cables to live another 30 years.
Sorry to hijack the thread momentarily, but I live my life mending and running cables, and I have become over the years, quite the Cable Nazi.
Good luck with your repairs,
Jez
84 K100 RS
Chassis number     0080546
5Back to top Go down   Front Brake Feed Pipe Empty Re: Front Brake Feed Pipe Fri Oct 31, 2014 12:52 am
Get that bracket off the triple clamp ASAP or the steel tube WILL break.
6Back to top Go down   Front Brake Feed Pipe Empty Re: Front Brake Feed Pipe Fri Oct 31, 2014 2:38 am
CraigNZ
CraigNZ
Am glad I asked the question...
It will be coming off first thing tonight (and the tape!)
Thanks guys.
1991 BMW K100RS
1999 BMW R1100S
7Back to top Go down   Front Brake Feed Pipe Empty Re: Front Brake Feed Pipe Fri Oct 31, 2014 5:52 am
Good info Jez.
Thanks.
8Back to top Go down   Front Brake Feed Pipe Empty Re: Front Brake Feed Pipe Fri Oct 31, 2014 8:43 am
CraigNZ
CraigNZ
Agreed, took me ages to get that dam tape off!
Released the bracket from the triple clamp, it sprung back, thought I heard a sigh from her as well...
Great forum.
1991 BMW K100RS
1999 BMW R1100S
