1 Right Horn not working K100 RT Tue Oct 21, 2014 4:54 pm
bignews1and2
While removing the tank to change the antifreeze I disconnected every connection I could find and sprayed WD40 in it before reconnecting. I have since bought DEOXIT and will redo this winter. I checked the connections on the right horn and they are solid.
Did I not reconnect the right horn at the source while under the tank?
According to my understanding of the electrical diagram they share they same source (Green-Gray). So if one works the other should work?.
Any advice on further troubleshooting? Just being lazy by asking. My next step would be to connect right-horn to left-horn wiring and vice versa...
1985 K100RT 0052326
