1Back to top Go down   Spring removal Empty Spring removal Wed Sep 24, 2014 1:31 am
Rickmeister
Rickmeister
Any suggestions out there as to how to remove the spring from a rear shock assembly?
2Back to top Go down   Spring removal Empty Re: Spring removal Wed Sep 24, 2014 2:55 am
3Back to top Go down   Spring removal Empty Spring removal Wed Sep 24, 2014 4:53 am
You been under the chop yet Rickmeister?, still fiddling with the bike as well I see.
4Back to top Go down   Spring removal Empty Re: Spring removal Wed Sep 24, 2014 5:27 am
Mossy1200
Mossy1200
Lots of big thick cable ties is my preferred method.
I strop the back of my bike down and then cable tie the spring.
Un-strop the bike and remove the shock.
I live life on the edge though.
5Back to top Go down   Spring removal Empty Spring removal Wed Sep 24, 2014 7:43 pm
Is this on your new shock mate, or something else you ve found.
6Back to top Go down   Spring removal Empty Re: Spring removal Thu Sep 25, 2014 4:43 am
uli
cant you just wind the compression nut back enough till the top (erm bottom ) retainer plate loosens off and then becomes removeable ???
a good pic would help mate !!!
7Back to top Go down   Spring removal Empty Re: Spring removal Thu Sep 25, 2014 9:13 pm
Rickmeister
Rickmeister
Charlie!!  Sometimes one can't see the forest for all of the trees! You know me...if there's an easy way and a difficult way, for some reason or other I take the difficult way.
Thanks, mate...worked a treat.
