1Back to top Go down   Wheel widening  Empty Wheel widening Sat Apr 06, 2013 2:06 pm
Oldgoat
Oldgoat
Hey Folks,
Anyone have a shop/individual with the skills to do weld-ups on the stock wheels?
Thanks,
OG
2Back to top Go down   Wheel widening  Empty Re: Wheel widening Sat Apr 06, 2013 6:42 pm
I've seen and come across companies who will do this for steel wheels but not Aluminium OG (Nice to see you back online by the way!). Start with some local enquiries with people in the modified car/Drag racing/Drift racing scenes they can be a good source of info.
Wheel widening  Ir-log1188....May contain nuts!Wheel widening  Ir-log11
K75RTP - 1994
3Back to top Go down   Wheel widening  Empty Aluminum Welding Sat Apr 06, 2013 6:51 pm
tio Jaimito
tio Jaimito
I help my friend build These. And when we do aluminum welding the heat changes the size, warpage and chemistry of the extruded AL. Not saying it can't be done but one would have to be a very talented person. Or there are special techniques for the process for welding casted AL. Good Luck. Jim
Krazy Kat. 1985 K100RS Alaskablau 13000miles 8valve "Black Belly"
Peggy's 1987 K75s Columbia Grey 9500miles 6 valve.
Wheel widening  K100_m12
Wheel widening  K75_po12
Wheel widening  Basil_10
http://www.nachicagonorth.com
4Back to top Go down   Wheel widening  Empty Re: Wheel widening Sat Apr 06, 2013 9:42 pm
Oldgoat
Oldgoat
Thanks for the info guys. Doing more research I'm finding out this requires a much higher skill set to do properly than I would have guessed at first glance. I will keep you posted on progress and yep 88 it's great to have a bit of time for my brick passion again and fingers crossed it lasts thru the summer!
OG
5Back to top Go down   Wheel widening  Empty Re: Wheel widening Sat Apr 06, 2013 9:49 pm
AL 58 here has the wheels used by dragracers on his outfit. Not sure if they are Cragar brand but they make them. You will have to make your own centres but they are good quality and quite suitable for 300mph cars. Al will give you more info when he is around I am sure. Won't ya AL.
6Back to top Go down   Wheel widening  Empty Re: Wheel widening Sun Apr 07, 2013 7:21 am
Rick G wrote:AL 58 here has the wheels used by dragracers on his outfit. Not sure if they are Cragar brand but they make them. You will have to make your own centres but they are good quality and quite suitable for 300mph cars. Al will give you more info when he is around I am sure. Won't ya AL.
You're wrong actually Rick. The rims themselves 'might' be sourced that way, but the rear centre is a machined billet original, made for the purpose, the front centre is made from two spun aluminium centres and a machined bearing carrier. Made in South Oz.
'93 K1100LT
Wheel widening  K-dogs10
7Back to top Go down   Wheel widening  Empty wide wheels Fri Nov 21, 2014 11:05 pm
arbalest
Kosman specialties can do most anything to your wheel. My 85 K100 has wheel that was widened. You have the option of leaving the wheel the original diameter, or increasing it by one inch.
8Back to top Go down   Wheel widening  Empty Re: Wheel widening Sat Nov 22, 2014 12:20 am
Mossy1200
Mossy1200
Its not legal to do it in New Zealand to a cast alloy wheel for the road.
I have heard of it being done on some post classic race bikes here though.
9Back to top Go down   Wheel widening  Empty Re: Wheel widening Sun Nov 23, 2014 5:26 pm
Kosman is now under new ownership but wheel widening can still be done.
Kosman
