1Back to top Go down   Steering head bearing parts Empty Steering head bearing parts Mon Sep 15, 2014 4:52 pm
BooG
BooG
Just checking the spec for the bearings on a '88 K75....320/28 X/Q   SKF
Will I need a steering head bearing metal cap as well?
2Back to top Go down   Steering head bearing parts Empty Re: Steering head bearing parts Tue Sep 16, 2014 6:23 am
mike d
If you are talking about the metal dust cap that sits on the bottom yoke under the lower taper roller bearing, then yes, as you are likely to destroy it when removing the old bearing. They don't cost much.
Mike
